does anyone have......
Old Apr 11, 2007 | 11:50 PM
JayFromPa's Avatar
JayFromPa
Default RE: does anyone have......
ORIGINAL: mdog2222
Ditch the front turn signal altogether, dude you've got a bobber!! Problem solved.
[IMG]local://upfiles/28108/78D50B3BC7F74A12B6DD553B05493E5D.jpg[/IMG]
IMO, not a real smart idea, considering alot of you bob guys are already riding black bikes and if your making a turn it's not a bad idea to let the opposing cagers know which way your going at nite.
Old Apr 12, 2007 | 12:25 PM
rodnreel's Avatar
rodnreel
rodnreel, does the stock light thread onto the stud on those Kuryakyn mounts ok? I was thinking the stock lights were 5/16-24 and the Kuryakyns were 5/16-18. If those work, I wonder if the 2390's would work also.
You're right.... the threading is different. But that was solved with a trip to Ace Hardware, I bought 2 new button head bolts to attach the signals.
Old Apr 12, 2007 | 12:51 PM
98fxd's Avatar
98fxd
has anyone considered just cutting the harley ones down? im not sure how the mounts work but i wonder if its feasible to shorten them. i like the idea of mounting the signals to the lower tree becasue i also use the harley windshield and ithink the fork clamp style will raise my windshield too much.
Old Apr 12, 2007 | 01:03 PM
carltex's Avatar
carltex
Shortening them probably isn't possible since they are probably castings and are hollow. Good idea though.
Old Apr 12, 2007 | 01:33 PM
rodnreel's Avatar
rodnreel
Right... You can't cut the HD down to a shorter length, they are cast and hollow.
Old Apr 12, 2007 | 01:48 PM
murphdog's Avatar
murphdog
rodnreel, thanks for verifying the tread pitch difference. How exactly did you mount the lights to the Kuryakyn mounts with the button heads?
Old Apr 12, 2007 | 03:56 PM
rodnreel's Avatar
rodnreel
These aren't the Kuryakyn brackets but give you a better picture on how they're assembled. The bolts that attach to the turn signals are countersunk in the brackets, to allow the bracket to fit the fork tubes flush. If your bolt heads are to tall (stick above the hollowed area for the bolts) the brackets will not wrap flush around your tubes.
Worse case.... You buy the correct bolt and thread pattern, and grind the head down a few mm to geta proper fit.
The ones pictured above are from Darg Specialties:
http://www.dragspecialties.com/fatbook/18/578/3900314
I hope this better explains everything.
Old Apr 12, 2007 | 03:59 PM
thrillseeker's Avatar
thrillseeker
these are from Drag Specialties. They extend out, but they don't look awkward
Old Apr 12, 2007 | 04:28 PM
TOMMAY's Avatar
TOMMAY
Kury 49mm clamps.
Good Luck
Tom
Old Apr 12, 2007 | 05:29 PM
murphdog's Avatar
murphdog
So...on the 2 piece Kuryakyn mounts, what I thought were 5/16-18 studs that screwed into the mount arein realitybolts thatpass through a countersunk thru-hole in the mount. All you have to do is replace them with 5/16-24 bolts. Thanks for the clarification and for the picture Tommay.
IronAK
Nov 10, 2015 12:15 AM
Captain Smooth
Apr 5, 2012 08:20 PM
fishercat
Dec 18, 2010 06:56 PM
jburriss02
Mar 17, 2009 12:02 PM
Rott3n
Sep 6, 2005 08:52 PM
