just bought progressive 412s
Old Oct 11, 2014 | 03:00 PM
apetterez's Avatar
apetterez
Default just bought progressive 412s
I'm getting rid of the stock chrome 12" rear shocks and installing black 11" progressives 412s on my 03 fxdl.
Two questions. Is the Inatal as easy as two bolts off two bolts on? Anything I need to know?
And can the progressives be installed so that the logo is not visible. I don't want logos brands or what not visible on my bike.
Old Oct 11, 2014 | 03:13 PM
1999 Wide Glide's Avatar
1999 Wide Glide
I like my 412s they are a vast improvement over stock. I think the logos are stickers and can be removed. It is just jack up the bike remove two nuts, replace new shock and torque the nuts. Repeat for the other side. Took me less than an hour to do on my Wide Glide.
Old Oct 11, 2014 | 05:46 PM
apetterez's Avatar
apetterez
What are the torque values?
Old Oct 11, 2014 | 06:34 PM
shiftace's Avatar
shiftace
Couple things to watch for after installing shocks that short. You may have to adjust the rear belt since the swingarm is gonna be at a different angle. And be aware that now there's a good chance you're gonna scrape any low hanging parts a lot. pipes, controls, frame rails etc.
Old Oct 11, 2014 | 06:45 PM
ynots's Avatar
ynots
The hardest part on mine were getting to rubber bushings into the end of of the shocks. I ended up using some air rifle lube and rocked them back and forth with a multigrip clamp. I tightened down them with my guessomation meter
Old Oct 11, 2014 | 06:50 PM
BigDogIdaho's Avatar
BigDogIdaho
Shocks - 15 mins by myself with no jack
It is easier with someone else helping you.
Old Oct 12, 2014 | 10:31 AM
1999 Wide Glide
I looked it up in the service manual.
Old Oct 12, 2014 | 04:21 PM
bullast's Avatar
bullast
I really want to get different shocks for my '14 SB.
Most people I see doing this go with shorter (lowering) shocks.
I want taller shocks.
Anyone know any options?
Mainly I want them black.
I figure if Im gonna change them I want them to be taller to give me more clearance and a bit better handling since it will reduce the trail just a bit.
Old Oct 12, 2014 | 05:18 PM
Racqueteer9's Avatar
Racqueteer9
Putting 1" taller 440's on my bike was the best upgrade I've done.
Old Oct 12, 2014 | 05:35 PM
2500hdon37s's Avatar
2500hdon37s
guaranteed it'll handle better than a lowered bike. lifting the rear will help get just a little more weight transfer to the front tire too so you can really dig into the corners with a tad more brake if you need to and roll on the throttle coming out a little sooner.
