I HAVE A PROBLEM!
Old Apr 13, 2007 | 02:28 PM
07bobber's Avatar
07bobber
Default I HAVE A PROBLEM!
I CHANGED MY MID CONTROLS TO FORWARD CONTROLS ABOUT A MONTH AGO AND I LEFT THE SHIFTER SPLINE LOOKING THING STILL IN THE PRIMARY, OF COURSE I WENT GHETTO AND JUST ZIP TIED IT TO THE SHIFTER ROD BUTTHE ZIP TIEBROKE ON A RIDE YESTERDAY SO I HAD TO NURSE IT TILL I GOT ANOTHER ZIP TIE. HOW DIFFICULT IS IT TO REMOVE IT? DOES THE INNER HAVE TO COME OFF? CAN ANYONE TELL ME STEP BY STEP WHAT TO DO?
Old Apr 13, 2007 | 02:54 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Default RE: I HAVE A PROBLEM!
Zip tie! Wedge that fukr behind the bolt coming out the crank case.
Old Apr 13, 2007 | 05:37 PM
davidchristopher's Avatar
davidchristopher
Search. I've spelled out the steps a few times now.
Old Apr 13, 2007 | 06:47 PM
Mascman's Avatar
Mascman
I used a metal bracket to securely anchor it to the cylinder.
Old Apr 13, 2007 | 07:02 PM
jackyl's Avatar
jackyl
ORIGINAL: HOGRIDA_06
thats what i did, not a problem for 10,000 miles either
Old Apr 13, 2007 | 07:03 PM
BlueShift's Avatar
BlueShift
Before you make another move, hit the caps button.
Old Apr 13, 2007 | 08:04 PM
rob_will's Avatar
rob_will
It is not very difficult to do. Just make sure that you have a maintance manual and the right tools. All together it took me about 8 hours total.
Old Apr 13, 2007 | 08:13 PM
dailydriver's Avatar
dailydriver
Dude save yourself alot of time Kuryakyn makes a cap that will not only hold it in place but will dress it up a bit....I'll see if I can find the part number...Later
Old Apr 13, 2007 | 10:38 PM
WS6 Formula's Avatar
WS6 Formula
ORIGINAL: 07bobber
You can remove the original shift shaft lever without removing the primary. Use a hacksaw blade and tape each end with duct tape, leaving about two inches exposed in the middle. Also put some duct tape on the primary and cylinder cooling fins. Tape a wrench onone end to get a better grip (on the end of the bladeso as you pull on the wrench you will be on the cutting stroke of the blade). Slip the blade between the primary and engine from the bottom of the bike with the wrench end on the bottom, grab the wrench end and guide the top of the blade with your other hand.I cut about three quarters thru then wrapped a rag around the shift lever and used vise grips on the other end of the shaft splines and sheared it off. [/align]Ialso used achrome carriage bolt http://www.chromebolt.com/51618-x-13...olt-p-845.html, put a rubber hose on the threads then added some shrink sleeving on the hose to get a nice snug press fit in to the empty shaft hole.
[/align]
Old Apr 13, 2007 | 10:49 PM
thrillseeker's Avatar
thrillseeker
