There has been more issues with S&S 106 cylinders than any of stock cylinders bored for 107. I believe S&S has recently changed their cylinders.
Also, Fuel Moto sells a heavy wall Cylinder as well.
What problems have come from the s&s cylinders? I'm shying away from the fm 107 because I've personally seen a set of cylinders that came from them and there was a huge wave in the middle of the cylinders. The engine builder had to send them back because they were so bad. Could have been a rare issue but I'd rather run a set of cylinders that were designed to be a bigger bore
Someone else to consider and just up north from you is Dan Baisley in Portland.
I went up and met him and was going to have him do some heads for me for my RK (little over ten years ago) but then had to go to Iraq and sold the bike (damn I loved that bike).
Check out his website, ....hmm, ....yeah, now you got me thinking
Thanks suede I'll look into that as well. Looks like I'm getting plenty of options and plenty of phone calls to make
Originally Posted by HD Bobber
Baisley is one of the great no doubt.
Who ever you go with for the heads the biggest recommendation I can make is don't go cheap on them. Heads are the lungs and the key to the entire build.....the rest are just bolt on parts. Guy who does your heads should tell you the rest of the build so that everything jives together.
Yea I don't want to cheap out and try and save a couple hundred bucks and regret it later. Makes sense to talk to the guy doing the head work before deciding on cams and comp ratio. Thanks again man
I believe it was something to do with the cylinder being out of round and tapper after low millage. Like I said they did re-design the cylinders and i doubt that was for the heck of it.
Are you sure you're not thinking of the old long stroke 106 kits?
Compression is all about cam choice. What you end up choosing for cams will dictate what the compression should be set at. T man likes compression with his cams. As long as it's matched to the cams and tuned well you won't have a problem. My bike is 12:1 with some long cams and I always run 91 or 93, I've run 89 when that's all we could find in nh and never had it ping in the heat and traffic. It's tuned very well though.
You can get some really nice headwork for around a grand, you don't need anything crazy. Make sure the head porter knows what throttle body you will be running so he can size the intake runner correctly. You really need to make sure everyone is on the same page when you're dealing with multiple shops to avoid headaches. Feel free to pm with more questions.
Well after talking to enough shops I've been talked into going with a 107" kit. Leaning toward Dave Mackies kit with his heads and 598 cams. I want to start ordering other stuff I will need. I'm still running the stock compensator and I'm thinking of going with the SE comp (there doesn't seem to be a lot of good options). Also with the tensioner I'm leaning toward to baker attitude adjuster. Anybody have any input on those parts? I'll probably throw on an Andrews 30t pulley while everything is torn down as well.
Don't see a lot of info on Dave Mackie cams/heads, should be interesting. Those 598s have an intake close of 50 degrees, what compression is he planning on? Should rip in the high rpms and a bunch of compression should take care of the lower rpms.
SE compensator, Baker adjuster, Andrews 30T with a heavy duty clutch spring will be a nice primary side set up. Sounds strong.
Can't remember but you are going to check the crank run out, right?
I have a s&s 106" kit on our wide glide. Using the S&S585 easy start cams, cleaned, polished throttle body, stage 4 head work. We got 114.8hp with 112.3 tq..
Hits hard at 3,000 rpm's and up.
I was looking for hp but got better tq than I expected.
There is so much out there now it is really hard to make a decision. I am a die hard S&S guy. Been using their parts since way way back with no problems.
The S&S 585 cams are one of my favorites. You can do a build in any direction with them. HP or TQ it all depends on how much you want to spend.
My 113 with S&S gear cams with stage 5 head work gave me 124.8 hp with 138 tq.
I'm pulling the motor and having the bottom end done. True/ weld the crank, timken all the good stuff. I need some miles out of this thing so I'm going to do it right. I'm waiting to hear back from DME they were checking if they had a set of grey heads and cylinders so they could get started on those so I could wait on tearing the bike down for a little while. When I hear back I will go over more details, he was talking 10.5 or 11 but I will post back when I know more. DME has a great rep, at least where I live, for his headwork so I'm pretty comfortable with him doing the work and they have been great to deal with so far
Yea tell me about it, I've been going crazy in my head trying to decide which way to go with this build. I was set on the S&S 106 or 107 but the more shops I talked to, the more comfortable I got with boring the Harley cylinders out. That megasphere piston and cylinder design that Mackie uses sounds pretty exciting so that was another factor in swaying me away from the S&S kit that uses the flat top pistons. I was going to go with the 585s but Monte over at Mackie was pretty convinced that their 598 would produce more power. Honestly I'm trying to do as much research and get as many opinions as I can on this, but I don't have a lot of knowledge when it comes to this stuff so I'm kind of winging it. I just got to trust the guys here on the forum and the guys at the shops that I've been talking to. The guys I know that are really knowledgeable with motors are old timers that know pans and evos so I don't even want to bug them with my dyna haha
