super glide tail/turn
Old Nov 12, 2014 | 06:30 PM
11bDad's Avatar
11bDad
I was rear ended on my new 2010 FXDC when it was only 4 days old. I had the dealer install the HD LED tail light when they were replacing the fender. It's no BAL, but it's better than stock. I then added the Custom Dynamics LED clusters to the rear turn signals (changed to red lenses), and the RBT module & load equalizer. The back of my bike is insanely bright. Couldn't be happier with the results. Something to think about. Good luck.
Old Nov 12, 2014 | 09:20 PM
barcoeng's Avatar
barcoeng
The custom dynamics integrated light is the one I run, and it's super bright.
Old Nov 13, 2014 | 07:29 AM
Crazy's Avatar
Crazy
Originally Posted by Jesse_81
This is what I did. Custom Dynamics plate mounted directly to my fender on my bob. Did this for two reasons. Cleaner look and so I was able to mount my bags. Don't have a pic of the turns sigs but they're BRIGHT yellow and are on the vertical sides of the plate. They WILL be seen no problem. I also wired it so that the yellows come on with the brake light all at once without sacrificing the turn sigs. It's bright. I love it, and I'm sure the people behind me dont... But that's the point lol. I ride it to work once in awhile and I'm in traffic at 5am while it's still dark out. This definitely gets your attention when all of them are lit up. (thats just the taillight on in the pic with the afternoon sun directly on it and it's still that visible.)
That looks pretty interesting to me. Could you tell me how that mounts to the fender? Do you drill four holes for the corner bolts, or is there some kind of mount underneath?
Old Nov 17, 2014 | 04:46 AM
badbowtie's Avatar
badbowtie
I am going to call custom dynamics this morning and I really do like the turn signal and brake light all built into the license plate frame. I just need to see if I need curved or the flat one. I need to check on radius to see how close it will be.
Old Nov 19, 2014 | 05:18 AM
badbowtie's Avatar
badbowtie
I ordered the license plate light frame that has the turn in the sides and brake light in center. From custom dynamics. Since I don't have any wires back their right know since all that was removed it is not s big deal to solder new wires all in. I would like to see exactly where all the wires are supposed to be even be ran factory to stay away from tire and everything.
Old Nov 19, 2014 | 08:36 PM
HD Pilot's Avatar
HD Pilot
On my Fat Bob there is a plastic conduit that runs along inside the rear fender(top portion)all the way to the underneath seat area.
Old Nov 21, 2014 | 05:20 AM
badbowtie's Avatar
badbowtie
I had the rear fender off last night again and seen the sticky residue where there would of been plastic conduit ran but of course all been removed I wonder if I can buy that a local hardware store.
Old Nov 21, 2014 | 07:45 AM
HD Pilot's Avatar
HD Pilot
I just looked in my HD parts manual, you can buy that conduit with the self adhesive directly from your local HD Parts Dept.
Old Nov 21, 2014 | 02:42 PM
badbowtie's Avatar
badbowtie
I flipped thru the big hd parts book I have and looked in dyna section and lighting section and I didn't see it all.
I did just find it on ebay.
Old Nov 21, 2014 | 03:23 PM
camden's Avatar
camden
I think HD Pilot was referring to H-D Part #70540-02 (CONDUIT KIT)
Check the OEM Parts Finder at Granite State Harley. If we're lucky, this link will take you right there.
Holy crap, I found the instruction sheet. http://www.harley-davidson.com/en_us...ts/-j01722.pdf
