Installing new primary cover question
Old Dec 5, 2014 | 07:06 PM
HyperM3's Avatar
HyperM3
Default Installing new primary cover question
So I got a new primary cover and in the instructions it says to disconnect the battery. So, why do I need to disconnect the battery to install this?
Old Dec 5, 2014 | 07:26 PM
hdbob2006's Avatar
hdbob2006
So when you pull it,if the starter shaft sticks to it,it"ll kick the solenoid on and spin the starter. So take the cable off to be safe.
jjtroutbum's Avatar
jjtroutbum
Edit.... safety first
Old Dec 5, 2014 | 07:33 PM
dmpjr's Avatar
dmpjr
It's for saftey reasons. I live on the edge, have never discod the battery to take off my primary. But thats just me.
Old Dec 5, 2014 | 08:31 PM
monster715's Avatar
monster715
Because every set of Harley instructions begins with disconnecting the battery. If it's the outer primary don't worry about it. If it's the inner then maybe but I probably wouldn't even then
Old Dec 5, 2014 | 09:00 PM
trainedkilla's Avatar
trainedkilla
I would not worry about the battery.
Old Dec 5, 2014 | 09:17 PM
HyperM3's Avatar
HyperM3
It is literally just the primary cover and gasket Im replacing. Not going internal at all.
Old Dec 5, 2014 | 09:54 PM
O-Town D's Avatar
O-Town D
You should be good. Just make sure the "IGN" and "RUN" switches are in the "OFF" position to prevent accidental startup. I did as much a few months ago checking the tensioner and no probs. Happy wrenching!
Old Dec 6, 2014 | 01:15 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Okay, just for ***** and giggles. Lets say you don't disconnect the battery and you're getting down and dirty with the primary cover but need to stand up to get a different tool or widget. You stand up and some how accidently bump the starter button when reaching up to balance yourself. Need I say more?
Old Dec 6, 2014 | 06:59 AM
DJY's Avatar
DJY
If your brain is larger than an almond, you should be ok not disconnecting.
