What did you do to your Dyna today?
Old Aug 21, 2015 | 09:38 AM
  #1001
dirtdreamer50's Avatar
dirtdreamer50
35MM film cans. Haven't handled any of those in decades. Nice looking mod there. tp
Old Aug 23, 2015 | 11:00 AM
  #1002
Qdog002's Avatar
Qdog002
Default Thunder Torque Inserts / V&H 3" Twin Slash Slipons
Had time today to install my W158 TTI`s with standard baffle, but needed a few modifications. Removed heat shields. Removed and rotated the baffle and drilled the hole. Intructions call for 3/8" hole in the pipe and baffle but only needed to ream out a 1/4" hole. Reamed existing hole in pipe. Then I had to cut down the bolts on the TTI`s so the heat shields would fit back over. Installed to get the right length, then removed and cut. Had to replace provided lock nuts( too tall ) with same size bottom nuts. Also replaced bottom washers with lock washers. Used blue loctite on both top and bottom nuts.
Anxious to do a few Powervision Autotune runs to see how the VE tables compare with the TTI`s installed.
Old Aug 23, 2015 | 11:21 AM
  #1003
gant's Avatar
gant
grips
Old Aug 25, 2015 | 10:21 AM
  #1004
Delldoe3030's Avatar
Delldoe3030
New skins and plasti dipped forks
Here's a link to the burnoff of what small amount of tread I had left
https://youtu.be/dG0i7aRvats
Old Aug 25, 2015 | 04:52 PM
  #1005
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
Looks good everyone!
Today I purchased a chrome voltage regulator cover - got an OK price on it. Nope, don't even have a Dyna motorcycle yet.
Old Aug 25, 2015 | 08:29 PM
  #1006
Whtwolf14's Avatar
Whtwolf14
Took the better half out for a lunch date ride. Since the weather is starting to change here in the mountains it was a pleasant ride; Not too, and not too cold...juuust right!
Old Aug 25, 2015 | 09:56 PM
  #1007
dublenut's Avatar
dublenut
Put some Michelin commander on the bike today. 200 on the rear 90 90 on the front. I have about 100 miles on the so far and they ride better than stock.
Attachment 524889
Old Aug 25, 2015 | 10:09 PM
  #1008
Ironcleveland's Avatar
Ironcleveland
Rode it to work. Dirty, but looking good.
Old Aug 25, 2015 | 10:54 PM
  #1009
dirtdreamer50
Not today, but Saturday, replaced the rear brake sending unit/switch. All works OK now. MoCo sure placed the reservoir in the hardest to get to place on the entire bike, but didn't let that stop me from rendering the repair. tp
Old Aug 26, 2015 | 04:19 PM
  #1010
KSJ08's Avatar
KSJ08
Bought some ride after I a friend pointed out the amount of wt on my front rim from the factory. Have 1300+ mi since new. I have notice some vibration or maybe it's just the way theFXDC rides?? Will try it out Saturday.
