What did you do to your Dyna today?
Old Aug 5, 2017 | 05:35 PM
  #7161
Crazy's Avatar
Crazy
A few things today: A smaller air cleaner cover and a tank lift to show off the engine a bit more:
Also new bars, risers, grips, and braided stainless clutch, throttle, and brake lines. This is a similar setup to what I had on the Street Bob before I went to the FL front end, so I know I like the riding position a lot:
Oh yeah, I forgot. I also de-reflectorized it. Frame stickers are next.
Old Aug 5, 2017 | 06:06 PM
  #7162
TinCupChalice's Avatar
TinCupChalice
Originally Posted by SixDD
Aye!
I re-positioned the bike in the shop. I can already tell the "betterness" of the progressive springs just by rolling it around in the shop. I set up what I want to do the wiring. Cleaned up the shop a little. Maybe I'll mess with it tomorrow.
::: snip :::
Wait until you ride it with those Progressive heavy springs You will notice immediately the improvement in the front...
Old Aug 5, 2017 | 08:03 PM
  #7163
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
I can hardly wait!
I wired up the right side. Covered the wiring with a sleeve after the shrink wrap then tucked it nicely up in the frame. You can see where the old meets new at the entrance to the frame.
I think I'll go do the other side tonight - need a nice long music break first.
Old Aug 5, 2017 | 10:22 PM
  #7164
Tall Timber's Avatar
Tall Timber
I can hardly wait!
Super clean (As always)
Old Aug 5, 2017 | 10:31 PM
  #7165
cggorman's Avatar
cggorman
Safe to assume the newer Dynas have wires entering both sides of the neck thru mirrored rubber grommets?
I need to figure out some way to make mirrored grommets for my 99 neck. My bike has a rubber plug on the right side and the left is stuffed clear full of ****. Looks like hell. I need to give that some thought.
Old Aug 5, 2017 | 10:48 PM
  #7166
SixDD's Avatar
SixDD
Finished up the wiring. I might mess with the throttle cables tomorrow. I'm done for the day!
Old Aug 5, 2017 | 10:49 PM
  #7167
Ghost_13's Avatar
Ghost_13
They do
Couple of ideas
Butt the plug up to the left side grommet - xacto knife.., cut out the plug center to match
Get some rubber / ribber-ized edging - glue it around the right hole - or both so they match
Ghost
Old Aug 5, 2017 | 11:21 PM
  #7168
cggorman's Avatar
cggorman
Originally Posted by Ghost_13
They do
Couple of ideas
Ghost
Good thoughts. I've got some rubber garnish moulding lying around. I'll have to take a closer look at the existing plug/holes. I know the plug is quite beefy. I think slicing a hole thu it would be trouble. Probably have to drill/melt. I'm also not sure if the plug will fit either side. If so, that's the ticket. If not, I've got experience with mold making and casting rubbers/plastics, but I'm a mediocre sculptor...at best. This may be a good application to revisit those old skills. Interesting little project....
ETA:
I did make it out to the garage today and got the welder fixed. Rewired it with a 25' (@ 10-3) power cable (came with a measly 8-ish) and fixed the air line. The Oetiker clamp was a bear. Buried way in there, but I got it once I held my tongue *just* right. Tested it (A-OK), Buttoned it up, and tucked it back on the shelf. That's all I managed. Maybe I'll throw some sparks tomorrow. We'll see how I feel.
Old Aug 6, 2017 | 12:10 AM
  #7169
Reindeer's Avatar
Reindeer
Cleaning up the wiring is on my to-do list, but I keep putting it off. That looks much nicer.
Old Aug 6, 2017 | 02:53 AM
  #7170
Northbound Southerner's Avatar
What bars did you go with? Do you have a side view photo? I am thinking about swapping out my apes as well...
