Throttle issue
Old Dec 25, 2014 | 10:24 PM
NickZ89's Avatar
NickZ89
Default Throttle issue
Was in the process of changing my bars(had the stock bars off) and was offered a possible trade for my bike. Went to put the stock bars back on and the throttle is locked up. Doesnt move at all. Keep in mind i did not disconnect any cables or anything in the process. Took it back apart and made sure the cable was in its tracks on the throttle tube, not really sure what else to try. Any advice is appreciated
Old Dec 26, 2014 | 02:23 AM
Mascman's Avatar
Mascman
Simplest thing to check is that you didn't shove the throttle tube up against the end of the bar which would jam it up.
Old Dec 26, 2014 | 03:32 AM
skinman13's Avatar
skinman13
did ya check the throttle friction lock? If you changed grips make sure the new ones fit the friction lock setup...had that happen once...new grips would not work with the friction lock setup..kept binding up every time I tightened up the switch housings
Old Dec 26, 2014 | 01:49 PM
NickZ89's Avatar
NickZ89
Yeah friction lock is fine. I never even separated the grip from the throttle tube. i will check to make sure its not pushed up against the bar like you said. Thanks
Maxxsmart
Mar 3, 2016 10:05 AM
rooti
Feb 9, 2014 10:56 AM
Bilco60
Jun 1, 2013 10:15 PM
AdrianVall
Dec 26, 2008 11:45 AM
ajdrr
Jul 2, 2008 10:28 AM
