Rebuilding forks
Ricor does not require drilling and are basically drop in, but i am not sure on how they handle i have installed several that where sent in when we tear down, powder and rebuild forks. i like the adaptability and rep of the gold valve emulators. Being that you are not drilling the damper rod they do not have the flow increase and response that the gold valve emulators have, but that would be a guess not a statement of fact
I would HIGHLY sugest you do your springs as well, be that progressive (what i run) or racetech, on a 98 those are prob pretty sacked out. i also run 15w spectro oil but race tech will tell you what would be best for your setup... do not let drilling the dampers worry you it is really easy to do
additional holes have to be added
