Primary oil level concern
Old Jan 12, 2015 | 07:00 AM
hitman1267's Avatar
hitman1267
Originally Posted by target64
I sure would be looking for some oil residue on the bottom side of the primary case!!
Other than the standard road grime, I got nothing under the bike.
Old Jan 12, 2015 | 07:02 AM
hitman1267's Avatar
hitman1267
Originally Posted by Warp Factor
After that amount of riding, check your primary level again. If it's gone significantly lower, that's not normal. Several places it could be going.
Great now I am worried.
Old Jan 12, 2015 | 07:03 AM
hitman1267's Avatar
hitman1267
Originally Posted by perki48
Drain the primary, put in the 1 qt. that it calls for and check it again. You can barely see the oil level when the proper amount is in the primary.
Roger that, that's what I'll do.
Old Jan 12, 2015 | 07:04 AM
hitman1267's Avatar
hitman1267
Originally Posted by Aires59
When you drained the oil did you look at the drain plug ? It has a magnet in the middle. It is usual for it to collect a black dust but if it has collected metal chips or flakes that is the time to be concerned.
There were very tiny particles, nothing significant.
Old Jan 12, 2015 | 07:06 AM
hitman1267's Avatar
hitman1267
Originally Posted by slyedog
Did you check the oil on the side stand or bike straight up and down. As stated right to bottom of diaphragm spring. Any drops where bike normally sits? Check the trans fluid level and when was it last changed? That would be my concern unless the primary tensioner went bad.
Changed the trans fluid about 1300 miles ago. When I last checked it, the fluid level was good. I had the bike on a lift when opened the clutch cover to adjust it. Thanks for the tip!
Old Jan 12, 2015 | 07:08 AM
hitman1267's Avatar
hitman1267
Originally Posted by dirtdobber
Check your oil level.
My manual says 26oz... on mine. 05 super glide.
If doing by sight make sure it is level not on jiffy stand. The fluid should touch the bottom of the clutch basket. Check you service manual for your bike.
Right, I checked the level while the bike was on a lift
Old Jan 12, 2015 | 10:13 AM
perki48's Avatar
perki48
[QUOTE=hitman1267;13587044]Right, I checked the level while the bike was on a lift[/QUOTE
The correct amount is 32 oz. in your six speed. To eliminate any further disagreement on amount required I will attach a scan of my Dyna's owners manual. I call your attention to the "two" warnings about over filling.
Attached Thumbnails Primary oil level concern-scan0001.jpg   Primary oil level concern-scan0002.jpg
Old Jan 13, 2015 | 05:43 PM
hitman1267's Avatar
hitman1267
[QUOTE=perki48;13587505]
Roger that, thank you!
Old Jan 13, 2015 | 06:08 PM
mltieman's Avatar
mltieman
6th Gear
I was wondering about the primary oil too when you mentioned about metal glittery stuff in the primary. I only had my bike for over a year now and last summer I had taken the primary cover off for curiousness to check the tensioner and see how the inside lookedm (my first harley... I took my tonka toys apart as a kid too). Well anyway, I noticed the primary cover and inner walls were caked with glittery sludge. My bike is an 08' RKC. It is my assumption that the primary never was pulled. Heck I don't know. I asked a HD service tech about it and he suggested I change the fluid and check the status of it again. I did not observe any suspicious signs of gear or chain wear that would cause this. I threw in Mobil 1 VTwin 20w-50 synthetic in all three. Cleaned the primary as thorough as I could too. Shifting was smooth as butter. Engine tappet noise at the top was noticeable but it seemed to run more calmer somehow.
Old Jan 13, 2015 | 11:06 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Lot of it was the clutch breaking in. Once the fuzz wears off (probably unmeasurable on the plates them self) there will be much less but the primary always has some crud and there is no filter. Why I change it and the transmission with the engine oil. Oil will still look new but some crude is removed. Probably does not make any real difference however. Note that the magnets are just for trouble indicators if a bearing goes..not real filters or metal catchers.
