throttle sticking
Old Jan 18, 2015 | 04:20 PM
maximuswaximus's Avatar
maximuswaximus
Default throttle sticking
lately my throttle has been sticking and I'm wondering if anyone has any advice on what could be causing this. any fixes i might be able to try
Old Jan 18, 2015 | 04:38 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Have you lubed the cable recently? Is it frayed at any place? Is the cable pinched or kinked? There's a plethora of things to check on. Better get busy
Old Jan 18, 2015 | 05:04 PM
JustOneDean's Avatar
JustOneDean
Have you checked the friction screw under the grip?
Old Jan 18, 2015 | 05:06 PM
2500hdon37s's Avatar
2500hdon37s
KY the cables and you wont have problems with sticking.
Old Jan 18, 2015 | 05:49 PM
maddghost's Avatar
maddghost
That is most likely it.
Old Jan 20, 2015 | 11:29 PM
amfhd's Avatar
amfhd
try moving the throttle out from the end of the handlebar.
Old Jan 20, 2015 | 11:59 PM
John_K's Avatar
John_K
Throttle and return cables may be a little tight, there needs to be a little slack in there. Loosen off the cable adjuster locknuts, slack the adjusters maybe half turn and see if throttle still sticks. At full close and wide open you should see the throttle and return cables slack off the throttle belcrank a tad once the stops are hit. Throttle should snap closed when released. May also want to inspect the throttle return spring at the belcrank... make sure it's doing its job and not broken.
Don't forget to re-tighten the lock nuts when yer done.
Old Jan 21, 2015 | 12:01 AM
John_K's Avatar
John_K
+1 on this suggestion as well
Old Jan 21, 2015 | 02:36 AM
fxdc_9613's Avatar
fxdc_9613
do you have aftermarket grips? I have Performance Machine grips and they started sticking a little bit. there was a little grime building up on the actual grip in the housing. so i just wiped it and sprayed wd-40 on it...good to go.
Old Jan 21, 2015 | 11:41 AM
motorend's Avatar
motorend
There is a small plastic shoe on the inside of the throttle housing on the other side of that thumb screw. I've had a buddy's come separated and sit ajar in there causing a sticky throttle. This can happen by unscrewing the screw too far and then screwing it back in but having it miss the center hole in the shoe.
