Tank Lift
Old Feb 7, 2015 | 09:07 PM
kevinckb3's Avatar
kevinckb3
Default Tank Lift
I have a 14 low rider and just purchased a 2" tank lift . I love the lines with a lifted tank .
I didn't put the kit on mine as I had a problem with clearance . The handlebar mounts are in the way and if I lift the tank I am estimating I am losing 1-2 inches turning each side . It doesn't appear that I can easily use a riser given
the design and how it all fits with the headlight bracket
Anyone else tried a tank lift on the new low rider? Any suggestions? ideas?
Thanks
Old Feb 7, 2015 | 10:22 PM
desertclassic's Avatar
desertclassic
I just raised the tank on the trike. 1 and 1/2 in the front and 1/2 in the rear. When I raised the rear it slightly changed the angle and also let me slide the tank back just enough to clear the bars and cables. Jim
Old Feb 8, 2015 | 02:29 PM
kevinckb3's Avatar
kevinckb3
Jim
thanks ! Ill have to look into that , I never considered raising the rear however using the rear to rotate it back may work ,, the low rider has an odd (to me) front handlebar mount that gives 2 points of handlebar adjustment
I'll put up a picture late
WH1_T-type
Jan 26, 2017 08:51 PM
sedynaglide
Jul 20, 2015 09:32 PM
jcmusic
Feb 17, 2013 04:59 AM
Ganooch
Jul 11, 2010 08:04 AM
frankh
Jun 24, 2007 11:00 PM
