Cam ?'s
Old Feb 9, 2015 | 11:47 AM
rauchman's Avatar
rauchman
Default Cam ?'s
Greetings,
Thinking about getting SE 204 cams or similar bolt in. I'm looking to make this as easy as possible. Not looking for headwork and what not.
From what I've researched, I need the cam, inner bearing tool, potentially new push rods and new gaskets. Is there anything else that I need for this install?
Thanks!
Old Feb 9, 2015 | 01:51 PM
stupid_rope's Avatar
stupid_rope
There are approximately 10,000 threads about cams...some even have pictures!
Old Feb 9, 2015 | 04:45 PM
tonebone_79's Avatar
tonebone_79
might as well throw in some new lifters while you're in there
Old Feb 9, 2015 | 04:53 PM
JMummery's Avatar
JMummery
New clutch spring. Might as well do tappets. SE install grease. Watch the YouTube to familiarize yourself
Old Feb 9, 2015 | 06:09 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default 204, you can do better...
There are lots of cams out there that will hands down outperform the 204 without any other modifications....
Woods TW-5-6 or TW-222
Andrews 48H
S&S mr 103
Depending on mileage S&S lifters
Originally Posted by rauchman
Greetings,
Thanks!
Old Feb 9, 2015 | 08:16 PM
rsking45's Avatar
rsking45
Go with Andrews 48. You wont be disappointed
Old Feb 9, 2015 | 08:28 PM
HD9358's Avatar
HD9358
Default just put cam's in my 08 dyna
if your shopping for good price's?? check amazon,that's where I got my Andrew's 48h cam's for 206.00 shipped... got the standard s&s lifter's for 103.00 there also, and the S%S gasket and bearing set for about 37.00... shopped ebay for the SE adjustable pushrod kit for 120.00 shipped... haven't put but a few mile's on bike since having the work done... but sound's great and seem's to run very nice... if you need any part#'s let me know....
Old Feb 10, 2015 | 09:20 AM
robbyville's Avatar
robbyville
Here is a link to my thread for cam change. First post has a full list of what's needed and part numbers (for a 2014 103 Dyna, not sure if that would be different for yours)
https://www.hdforums.com/forum/dyna-...am-change.html
Old Feb 10, 2015 | 10:38 AM
rauchman's Avatar
rauchman
Thanks for everyone's supplies. Yeah, I've read a few cam related threads already and am getting serious about the install.
I'm not going to get into "which cam", but looking for info on the "other" things that go with it.
Am I correct to assume that with a manufacturer listed "bolt in" cam, that no other parts are needed, aside from bearings and gaskets?
What is a lifter, and why is it necessary to upgrade for a bolt in cam? I know it's a popular upgrade, but what am I gaining? Also, tappets were mentioned as an upgrade. Is it necessary for a bolt in cam? What is gained?
Clutch - I've read some folks upgrade their clutch spring (at the expense of making the clutch pull heavier???). Is this necessary for a bolt in cam change?
Appreciate the info. Thanks!
Old Feb 10, 2015 | 10:39 AM
rauchman's Avatar
rauchman
Excellent! Thank you!
