Cam ?'s
Yes a bolt in is nothing else required and along with that your stock lifters should be fine as long they're not high miles.
A better air cleaner with more flow is recommended and a map....
The clutch spring or diaphram should be upgraded when upgrading the power to 100 lbs of torque to prevent slippage.
. I did replace mine just because.If you are sure that the base circle of your new cam is same as stock then you can keep your pushrods as well. I checked with Andrews and with the 57's there is an ever so slight difference from stock,could use the stock rod. BUT, if there is a slight difference then valve train could be noisier and with adjustable rods you can do exactly that, get them adjusted to suit. Also if using stock rods you will be removing tank and rocker covers to access the rods from above, no big deal apparently but will add some time to your install. Lastly, if going in from the top you will spend a little more on gasket changes (still less than new push rods though), as an example the Harley top end gasket kit is around $90, aftermarket ones in the mid $50's. I bought S&S quickee rods for $145 plus the fewer gaskets I needed when going that route, maybe $20 including cam chest, lifter covers (which you would not need if keeping stock lifters and going with quickee's), and exhaust headers.
Ultimately up to you, just make sure your choice of cam doesn't require a new rod and then decide what suits you best.
I've got just over 5k miles on my bike. I'm assuming lifters aren't needed? What is the theoretical advantage to aftermarket lifters? Is there some noticeable performance gain, or is this more for reliability?
In looking at the SE204 cams, most dyno's I've seen put HP at 90-95 and Torque just north of 100ft/lbs. Similar type cams provide dyno's that are, well, similar. In your clutch comment, would you recommend going with the upgraded clutch spring? I understand doing so makes the clutch pull heavier. Any work arounds on the heavier pull?
Thanks!
The "while you were in there bug".....I like that! Yeah, I could easily see that happening.
Unless otherwise recommended, I'd be doing the cam swap and using adjustable pushrods. I'm big on the easy factor (with reliability/durability), and going this route seems easiest.
I noticed in your sig, you're running the V&H FP3, as am I. Were there any issues using this tuner when you changed cams?
FP3, they will build you a map for your new cams. Go into the support mode of your app and email them, they have been working on a list of popular cams but in my case I supplied the specs. Once we worked on a challenge (that I created) the new map worked flawlessly, all this easily done in a few minutes. Once they create the map they will let you know, you turn on your bike and FP3, download and flash that easy. You can auto tune afterwards if you like, they recommended to me that I run a full tank first and frankly my bike runs better with this map than my last one.
You'll be happy I'm sure.
In looking at the specs on your bike, my plan is to go a similar route. I'm running Racetech Gold valves and springs in the front, have a set of 13" Hagon Nitros on order, stage 1 and...cams. Did you use lifters, clutch upgrades, etc.? I believe the power ratings and curve are similar to the SE204 (more power throughout with power peaking higher in the rev range…roughly 90+ hp/105+ ft/lbs). Are you happy with the characteristics of the Andrews 57H? Were you considering other cam choices also?
Sorry for all the questions...
I also changed out the clutch spring, jmummery (another forum member) did not and he has had no problems. For me I wanted to just get it done and for $35 figured why not. fWIW, I did not replace the primary gasket, it was just fine. The pull is a little harder and I have pretty small hands but it hasn't bothered me yet, it's not that much stiffer.
For my style of riding I asked around about the cams and there was a lot of consensus that for a stock 103 that the 57 would suit me well. I also thought of the S&S mr103 and others. I never really looked at the 204 for no other reason that in the catalog the curve didn't look as strong as some people's 57's. Truth be told I'd have probably been just as happy with them since I have no basis for comparison other than stock. But I got a good price on the 57's and I have to say based on my first couple of rides that they are pretty freaking awesome!
Thanks
