mids spline lock
Old Feb 15, 2015 | 01:16 PM
apetterez's Avatar
apetterez
Default mids spline lock
So there is this like lock that was installed to prevent the mid shifter splone from moving while forwards were being used. Well im switching to mids now since reduced reach forwards were still to far. So the problem im haveing is weather or not this bolt needs to go back in. Im pretty sure its a bolt that holds the cases together. If so whats it called so i can research torque value on it.
Seems like i cannot get it off completely until i pull the inner primary and that seems like a lot of work just to put loctite im sure ill be ok without right?
Attached Thumbnails mids spline lock-20150215_104107.jpg   mids spline lock-20150215_104004.jpg
cajun1957a
Aug 10, 2018 04:26 AM
BuckeyeUltra
Jan 14, 2017 02:04 PM
mechanicalman
Oct 21, 2015 09:21 AM
lkr0
May 6, 2014 09:24 PM
Whiffleboy
Jul 21, 2006 01:49 PM
