White Lettered Tires
Old Apr 21, 2007 | 08:47 PM
StaticSag's Avatar
StaticSag
Default RE: White Lettered Tires
The problem I ran into with using paint pens is the paint never really dried and after a few washes began to come off. I used a silver ink pen and the sharper point of the ink pen made it much easier and lasted much longer.
Old Apr 22, 2007 | 03:27 AM
Timmer's Avatar
Timmer
ORIGINAL: kpreese
I love the look, but I did something slightly different. I only painted the outlines of the letters. It's slightly more subtle, but I think it's a good look. I did NOT do the rear only because I've been putting it off, definitely a lot more of a pain to do.
Shortly after doing this, I put the springer on and the front tire I have for it is an old tire. I wanted to make sure the bike would ride OK with the springer before buying a new tire. A couple of pictures are below.
My experience was that the paint holds up amazingly well. I didn't find them a challenge to clean because the outlined part is raised. So it didn't take any deep, careful scrubbing to get down inside a depressed area or anything. That's probably another reason why the paint was holding up so well, because I didn't scrub the tires hard at all.
It's tricky to do, but I was careful as I could be and then I used a nylon brush dremel wheel and "erased" the stuff I didn't want. That sometimes meant having to go back and repaint a tiny spot. This is a good project for when you are broke and still want to do something for your bike. It's WAY more effort than $$$
Kevin
K, man you did a great job. Looksreal good.Kudos to you for being so patient. I'd have the whole f'n tire white by the time I got done, with my patience. Tim
AussieLowRider16
May 18, 2019 08:17 AM
Dreamtab
May 14, 2014 10:30 PM
standardmoose
Mar 26, 2014 03:25 AM
jackietan
Wheels/Tires
May 9, 2009 02:35 PM
Alias
Sep 8, 2006 05:18 PM
