I dont know why but my new performance machine renthal grips stick on my dyna.
The stock grips work but are ugly. Before anyones asks i did check the "cruise control" ****. I actually removed it.
I thought it was my cables but i adjusted them multiple times nothing worked. I switched back to the stock grip and it was smooth. Reinstalled the pm renthals and it sticks.
If I had to guess, the depth of the new ones might be slightly shorter, and it that's the case, the are sticking on the end of the bar itself. Loosen the throttle housing and try sliding the whole thing just slightly outwards (away from the bar end), retighten, and see if that relieves the sticking.
I have the same grips on burly narrow apes. I had the same problem when i first put the new grips on, i slid the grips outward ever so slightly and sprayed a bit of wd-40 where the grip rests in the control module and it works nicely now
also, you might check the angle of the entire control module/ grip. after tilting mine down a tad it rotated a lot easier too
Reason: another suggestion
