Hope you have better luck with your plate relocation than I did. I spent half a day putting my GBG plate and signal relocation last weekend and there is no way I can get my bags (same kind as yours) on my bike, they hit the turn signals. Good luck
Well if you put them on your SB then we'll have the same problem! I've seen them work but then also saw Squidhead's challenges where he had to use different stalks for the turn signals. I'm hoping for the best. I don't mind if they rub a little on the back of the signals so long as they're not pressing so hard that I run the risk of breaking the signals.
The only other thing I did was added docking hardware for a sisy bar, that may have pushed the bags out far enough that you can't slip the hard back of the bags behind the turn signals, I was pretty bummed when I went to put the bags on, I was like WTF, oh well, on to plan b.
So what is your plan B?
I'll be tapping my own threads into the stock plates. suede found me the pieces I needed but I figured I'd try something new!
Probably a custom dynamics plate frame with the brake, turn signals built in, Just hope the are bright enough, lots of shitty drivers on California freeways.
Mine rub just a little on the very back of the bullet part of the signal, nothing major. Definitely no need to worry about it breaking. I can post a picture if you'd like to see
