Big Inch Motor - Clutch ?
Old Mar 13, 2015 | 11:20 AM
HD Pilot's Avatar
HD Pilot
Another thing to consider is whether or not you will have to get a new primary chain if you change the compensator tooth count. On the pulley swap you are usually good for +/- 2 teeth, not sure about the primary chain.
Old Mar 13, 2015 | 01:05 PM
XFXDX's Avatar
XFXDX
I'm pretty sure it will be necessary. I'm about to put a call in to Baker. I've seen Illusion has a kit which includes the chain.
Old Mar 13, 2015 | 03:14 PM
XFXDX's Avatar
XFXDX
Baker has a 28 tooth compensator sprocket, good for a 9% reduction in RPM and, of course, a 9% reduction in torque.
"You won't win any drag races!" Mark tells me. Dammit. Can't have it both ways, I guess.
Has anyone done this? I'm thinking I oughta see how she goes before adding the sprocket. If a 27 was available, for a 6%, I might be more apt to try it...
It's a no brainer as far as hiway speeds, but the drop in torque as a trade-off is scaring me away. But, should it be...?
Old Mar 13, 2015 | 04:21 PM
monster715's Avatar
monster715
If the 111 is anything like this 124 I have, it's not going to mind the extra rpms on the freeway. The motor revs so smooth, it's nothing like the stock one shook. I can damn near read license plates out of my mirrors
Old Mar 13, 2015 | 07:13 PM
XFXDX's Avatar
XFXDX
WOW!!! So I'll wait to see about the taller gearing for now... I guess, in time, an OD6 will be in order. 😎
Old Mar 14, 2015 | 07:28 AM
vdop's Avatar
vdop
That's the key. I wouldn't want to give up any acceleration. Let it rev on the highway and save up for an od6.
Old Mar 14, 2015 | 04:56 PM
PWMORRIS's Avatar
PWMORRIS
Thumbs up
Originally Posted by HD Bobber
The SE spring will be fine, but if you have the funds and don't want to think about it ever again....not to mention have a lighter clutch pull and a ton more grab then get yourself one of these $500 clutch & hub setups:
Rivera Pro Clutch, Barnett Scorpion, Evolution Industries terminator, Bandit Sportsman
Yup, pay now or pay later....
As far as the 27 comp, I have one on one of my bikes, you can get one thru V Twin mfg, or moto hub.
Baker has the chain, ask for James, he will hook you up with the right one.
As far as Illusion, they don't make their combo set up anymore.
Price was high anyway...
Old Mar 14, 2015 | 06:55 PM
XFXDX's Avatar
XFXDX
Excellent, guys. Thank you.
Think I'll save up for the OD6, vs. The 27 or 28 now. And I agree, it's gonna be a new clutch. Just can't make up my mind on which! haha First world problems!
Old Mar 14, 2015 | 11:16 PM
dirtdobber's Avatar
dirtdobber
I am using the primo pro clutch and baker OD6 on my 113. I really like the primo clutch. It will handle anything I throw at it with ease.
Had the lower 3 gears changed for a better launch, went higher slightly. The torque takes care of it easy enough. As far as going with higher gearing. There is a point where higher gearing will give Lower et's. it's the torque that does it. I wouldn't want mine geared any lower. I'm not into wheelies.
Old Mar 20, 2015 | 04:18 AM
Lama's Avatar
Lama
The best clutch available today. Incredible quality, friction load and smooth as butter.
http://www.banditmachineworks.com/pd...ndout203RN.pdf
