Busy winter work
Old Mar 14, 2015 | 08:48 AM
Strobe's Avatar
Strobe
Default Busy winter work
Finally got done with my build and starting the breakin process.
107 build CP pistons with 6cc domes
Darkhorse plug/ welded crank and timkin coversion. Lefty bearing on the cam side.
Ported heads decked for 88cc with kibblewhite valves and springs good to .650 lift
S&S 585 cams
1.725 rockers on the intake side only
Drag specialties high performance oil pump and new cam plate
55mm HPI/1.8 runners with 4.9 injectors
R&R overflow air filter setup for external breathers
Screamin Eagle manual primary chain tensioner.
1.125 wide drive belt 30/68 pulleys
All the bearings in the motor/primary have been replaced.
Barnett CF clutch disks/ with the stock Harley disks for the 1st and last disk.
Barnett HD clutch spring.
Treated myself to new progressive 444 shocks.
Not sure exactly what I'll do on the breather arrangement. But this will get me on the road for breakin and dyno.
Quick clip of a heat cycle
Old Mar 14, 2015 | 10:49 AM
robbyville's Avatar
robbyville
Nice job and sounds incredible!
Old Mar 14, 2015 | 10:52 AM
HD Pilot's Avatar
HD Pilot
That's looks like a really well thought out build! Those rockers on the intake side increase your lift too right(cannot remember the # you multiply by)?Putting that 1 1/8" belt on is slick, I want to do that too. Are you going to dyno it? Nice work for sure!
Old Mar 14, 2015 | 11:40 AM
HD Bobber's Avatar
HD Bobber
Congrats very nice and solid build!
Old Mar 14, 2015 | 11:46 AM
NDBadlands4-2's Avatar
NDBadlands4-2
That was a lot of work. You must have long winters. Great looking bike.
Old Mar 20, 2015 | 06:19 PM
Strobe's Avatar
Strobe
I got it to the dyno today, She made 121.6hp 119.74tq. Clutch held great.
On a funny note..the computer crashed on the last run. Then they go to print out the sheet and they run out of ink !
I requested and was able to be there for the whole dyno process. That was pretty cool. Learned a wee bit more !
Old Mar 20, 2015 | 06:38 PM
Suede Blue Man's Avatar
Suede Blue Man
Nice! That made some good get-up-and-go; in the Castro district of S.F. they'ed call that a nice package
Old Mar 20, 2015 | 06:52 PM
Strobe's Avatar
Strobe
Many thanks to Target64, his build was an inspiration to head down this path. His 107 is incredible.
Old Mar 20, 2015 | 07:50 PM
target64's Avatar
target64
I just started reading your post and said to my self well ole strobe is doing the same build. Well u did a very nice job and your bike sounds awesome. you will be impressed with the performance you have now. was 121/119 in forth gear ?
Old Mar 20, 2015 | 08:37 PM
Strobe's Avatar
Strobe
That was a 6th gear run to get those numbers. I'm running a 30/68 combo. At 60mph in 6th gear I'm running 2450 rpm.
I had a local guy do the heads. It was all a hand port job. He does'nt flow the heads either. He mentioned no one want to pay the price for getting the flow work done. I put my faith in his experience. He was skeptical about me picking the HPI 55mm. The results sure changed his mind.
Appears the fatcat perforated baffle must have hurt torque a little.
I was really impressed with how the clutch feels. I still have a great friction zone and she hooks up. And I run formula+ in the primary. Good for the compensator.
Alot of reading/research went into this.
