Tire Balancing
15-20 min is all you need.
Use the 2X4 method of breaking the bead. (look on you tube) Then two 9 to 12" tire irons. Some plastic rim protectors and dish soap/water mix for lube.
The following is an example. Except he needs to turn the boards under the tire 90 deg so the foot in back is not needed.
Nice for a rim holder to polish the rim and bearing changes, too.
Doesn't work without the right size tire, though.
If you do your own tires i would avoid this tire, you will have to cut off
Imold, tell me about that tire changer. How much and how well does it work? I saw something similar at Harbor frieght that was pretty cheap.
Alot of shops around here dont want to do "internet tires", which i understand because they are in the business of sellin tires, but dam you get good deal on internet tires.
To the OP, i have never had a mc tire rebalanced in between installs. To me i have never thought it needed it because a tire doesn,t really last that long anyway.
Now my michilin truck tires lasted 85,000 miles and i had them rotated and balanced afew times
I had a shop install dyna beads when i got a set of wheels powder coated and they seemed fine.
I've seen guys on this forum say they paid $700 plus to have a new set of tires put on, riding the bike to the dealer. My changer (came with a balancer, too), hi lift jack, and a pair of Avon tires was less than that.
I was sure glad I was doing it myself when I changed the front tire on my 1200, a spoke wheel with tube; the rim had a crack running down the center of the butt weld for the rim, on the inside. There was just enough rust to cover it, but I cleaned the inside of the rim out real good, and then saw it. I doubt a shop guy would have bothered cleaning it, let alone look at it well enough to see the crack. Might not have even pulled the rubber rub strip out that covered it (I always use new rub strips and tubes for tube tires). I'd never even thought of that weld failing before...
Here's NoMar's website, just follow the links for their different changers and how to videos. http://www.nomartirechanger.com/
Outta balance tires bounce up and down, not side to side as in 'death wobble'.
Nice setup you have!
