So i got the exhaust on, started it and its throwing front 02 sensor low. I took it off tried tightening it, and it's still giving me the code. I can't get it any tighter, so I'm not really sure what's wrong. Any Ideas? Also my awesome wife help me with the take of and install.
This may sound dumb but you're sure you re-connected the sensor to the wiring harness?
just a thought ,at one time we were told not to use antiseize on o2 sensors due to the grounding through the pipes and the anti seize can insulate it and cause it not to read correctly, The only other thing I could think of is if somehow the sensor tip got contaminated with oil or if you used it, antiseize. also you could check for a loose connection or pinched wire on it.
yea ill check that out. I didn't use antiseize but maybe something else got on it/ possibly pinched somewhere.
