06 street bob, trouble starting, looking for help
Old Apr 19, 2015 | 02:24 PM
Jason Baggs's Avatar
Jason Baggs
Stage II
Default 06 street bob, trouble starting, looking for help
Hi everyone, new to posting on here but I've read the forums a few times and they've been helpful, hoping for the same result so here goes.
I have an 06 street bob, 35,000 km on it. I've had it almost three years.
Suddenly, it starts acting up on me. It's always been pretty easy to start, now it is just turning over and not firing up. Like it's not turning fast enough or bad gas was my original guess... Killed the battery yesterday trying to start it. Diluted what little gas was in it with new premium (only gas I ever use, no ethanol), charged the battery and it ran fine.
Then today, I get it running, ride for about 30km with my son and we stop to have a coffee, when I try to start it back up. Same thing. Only this time I get it running and as I'm making the turn to head home the bike completely dies on me, no lights, indicators, nothing.
Shut the key off and try again and just get it started. My son jumped on and we got it home. It died trying to put it on my lift and hasn't started since.
It tested my battery 12.6v, my fob battery 3.3v, tried pulling the fuse on my stereo, same thing.
Recently serviced by me, engine oil, spark plugs, primary oil....
any thoughts are appreciated.
Old Apr 19, 2015 | 05:23 PM
greg3131's Avatar
greg3131
35,000 km is 21,748 miles , 30 km is 18.6 miles .
good luck Jason
Old Apr 19, 2015 | 05:58 PM
Jason Baggs
Stage II
Thanks Greg for the info, I'm Canadian so I automatically measure distance in km and time in how long it takes me to drink a Tim hortons coffee..... Eh.
That being said, I did find a thread on here that indicated a fuel line problem. A quick check through the fill cap when the bike is priming on start and there's gas spraying inside the tank.... So I've got a fuel line leaking.
This also explains from my post why when I diluted the gas in my tank yesterday by adding a bit more, my bike seemed to run fine. Once I burned the tank down to where it was yesterday..... Same problem.
Could this also explain a slight loss in power over time? Seems like the bike doesn't rev up as high as it used to...... Hope so.
Now to fix it. Oh well, better to go through this now than a few months time when I'm half way to Sturgis!
Old Apr 20, 2015 | 09:17 PM
TexasScooterTrash's Avatar
TexasScooterTrash
The battery voltage should be greater than 12.6 volts. More like 13.5 volts. Go by the manual and check your stator output voltage. Sounds like you are running off the battery. With yours being an 06, my vote is on a bad stator. Go aftermarket with the parts, just don't waste money on the crap from China. You can find useful videos on You Tube to help you out.
Old Apr 21, 2015 | 02:06 AM
Warp Factor's Avatar
Warp Factor
Battery voltage of about 12.6 is normal when the engine isn't running.
rebel7
Jun 24, 2019 01:03 PM
dcindurham
Nov 9, 2015 10:19 AM
PigInaBlanket
Feb 19, 2013 09:08 PM
sara
Aug 13, 2006 01:16 AM
Lowman
Nov 14, 2005 04:52 PM
