Messed Up...First Drop
Old Apr 21, 2015 | 08:00 PM
Rowdy Fetus's Avatar
Rowdy Fetus
Default Messed Up...First Drop
Well it happened. I feel like such an idiot.
Got caught in some rain and wind, made it home just fine but I guess the bottom of my shoes were wetter than I thought and went I went to put my left leg down, it slipped from under me in the parking lot. I tried to keep it up for as long as I could but the inevitable happened and I laid her down. Real gentle but laid her down nonetheless.
I started it up no problem and at first I wasn't able to get it into neutral (I could shift normally but the green N wasn't coming on so I turned it back off, turned it on again and then it worked. Other than that, no real damage just a little plasti dip came off the derby cover. No worries at all.
Sorry for the noob question but the only thing bothering me is the clutch lever seems loose. I know it's normally looser than the brake lever but if feels wobbly. Does it need a tighten? Am I just being paranoid?
Any advice?...go easy on me lol.
Old Apr 21, 2015 | 08:18 PM
LunaticFringe's Avatar
LunaticFringe
never seen a wobbly lever on a Harley, did you bend the bars? do you mean it wobbles up & down or side to side? if side to side you probably should just re-adjust the clutch.
I know how you feel, feet slipping, happens all the time, so annoying. just shows how much traction you loose in rain.
Old Apr 21, 2015 | 08:19 PM
XFXDX's Avatar
XFXDX
You're probably just being paranoid. Forget about it, bud. Happens to the best of em!
Old Apr 21, 2015 | 08:26 PM
JustOneDean's Avatar
JustOneDean
Important thing is that the clutch fully engages when you release the lever, and fully disengages when you pull the lever all the way in. As long as it does, you're good.
Old Apr 21, 2015 | 08:38 PM
Suede Blue Man's Avatar
Suede Blue Man
If you're like most you got one bike but two legs, legs is for sacrificing to break the fall of the bike. Next time don't be a and keep that leg down there.
Hell, it's cheaper to fix a leg in a hospital than a harley at the shop
Good luck with it and the advice above
Old Apr 21, 2015 | 08:39 PM
EricInNCa's Avatar
EricInNCa
Well, now you can check that off your list of things NOT to do again. Don't be to hard on yourself. $hit happens. At least you didn't wrench your angle or knee....
Old Apr 21, 2015 | 08:49 PM
robbyville's Avatar
robbyville
Yup now it's done so you don't have to think about it happening again!
On the clutch lever, could it be that the metal clip that keeps the lever blade tight against the handle bent in a bit (think inverted C, or the same type of clip that is holds your foot pegs snug but still allows them to fold up)?
Happy you're ok though
Old Apr 21, 2015 | 09:05 PM
Rowdy Fetus
Basically, I can push the clutch lever out further than where it sits. I don't know if it was like that before or not though. It does seem to wobble up and down as well.
Thanks everyone for quick responses.
Old Apr 21, 2015 | 09:12 PM
Rowdy Fetus
...oh also, no I didn't bend the bars. Everything looks good up top, the hand guards got a little scuffed but it's barely noticeable.
Old Apr 21, 2015 | 09:23 PM
1999 Wide Glide's Avatar
1999 Wide Glide
Just be thankful you weren't on a charity ride with your OL onboard like I did this weekend. It happens to everyone sooner or later. Be thankful as I am that no one was injured especially the Boss. If you know what I mean.
