Rear tire questions
Old May 1, 2015 | 05:07 PM
slickster5150's Avatar
slickster5150
Default Rear tire questions
This is probably a stupid question but I am wanting to go to a wider rear tire on my 2000 Fxd Super Glide what is the widest I can go without having problems with the rear fender and rear belt.
Old May 1, 2015 | 05:53 PM
Rayvan's Avatar
Rayvan
Your stock rim will fit a 150 width. Some of the Dynas made that year had them stock.
Old May 1, 2015 | 07:17 PM
slickster5150
OK what width of wheel and tire will fit if I decided to change my rear wheel and what is the widest rear wheel that will fit?
Old May 2, 2015 | 09:58 AM
8541hog's Avatar
8541hog
Check your side fender clearance, that will give you an idea how much wider the tire can be, unless you are willing to do more than just a simple tire/wheel swap.
Typically 10-20 mm is all you can do without other mods to keep from tearing things up.
rickss69
Jun 21, 2011 06:48 PM
RFG40901
Screamin Eagle CVO Models
Nov 3, 2010 06:50 PM
dano1200R
Oct 21, 2007 05:34 PM
drdave
Jan 20, 2007 09:17 PM
huskerhog
May 31, 2006 12:43 AM
