FXD sorted, thanx to forums
Old May 3, 2015 | 08:13 AM
allsop's Avatar
allsop
Default FXD sorted, thanx to forums
I did lots of reading this time (here) before jumping into my FXD.
Stock bike with the exception of V&H long shots slip-on's is where I started. The changes I made are as followed:
SE pushrods
Gatorman's lifters
Andrews 26H cams
Thunder-max ECM
It is no longer the same mcycle, all the bad and disappointing habits are gone, has turned into a complete animal. Makes you feel like you have a Tiger by the tail. Next will be Iridium plugs and High flo air cleaner, after that BRAKES and suspension to compliment.
Once some miles are added, the T-M will be fined tuned even more which is hard to believe the bike can run even better. My only concern with these changes are the push-rods, am wondering if I should have loc-Tight'd the jam nuts ?
EDIT: replacing the INA bearings is where all these mods started.
Old May 3, 2015 | 08:17 AM
QC's Avatar
QC
I didn't. Have had no troubles.
Old May 3, 2015 | 09:31 AM
HD Bobber's Avatar
HD Bobber
SE pushrods
Gatorman's lifters
Andrews 26H cams
Thunder-max ECM
Nice man glad to hear all is well with the bike. After some miles go into the t max control center and run the auto map which will dump all the learned offsets and optimize your tune(if you have the closed loop auto tune version of the TMax).
opd1264
23
Jul 9, 2019 04:59 PM
Andy Knell
Aug 14, 2015 08:00 AM
South Jersey Scooter Trash
Nov 2, 2011 07:36 AM
fireaxxe
Jan 26, 2011 12:12 PM
I CUT 1
Jan 1, 2009 09:34 AM
