Air Intake question
Old May 13, 2015 | 09:19 PM
Jesse(J-Bird)James's Avatar
Jesse(J-Bird)James
1st Gear
Default Air Intake question
This if for all you Harley guys out there I'm looking at buy air intake kit for my 2014 Street Bob but don't know which one to go with its either
1) Screamin Eagle Heavy Breather
2) Screamin Eagle Extreme Billet Air Cleaner
juts wondering if they both have the same performance power and the only difference is looks. If there is anyone out there that can help I would appreciate it Thanks
Old May 13, 2015 | 10:12 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
A "Stage 1" AC is just that, an AC. No power advantage to either model by itself. You'll need the exhaust to go along with it, along with a fuel modification of some sort to enrichen the ratio so the bike doesn't lean itself out and burn up.
Old May 13, 2015 | 10:21 PM
JohnMn's Avatar
JohnMn
It's just the looks.
Without adding another several thousand dollars worth of cams, pistons, heads and porting work to change the engines ability to use air, the performance difference is little too none
Old May 13, 2015 | 11:14 PM
2500hdon37s's Avatar
2500hdon37s
Check out DK customs intakes. Much more cost effective and MUCH better options for crank case breathers, they get the breathers pumping oil mist out of your intake. with 4k miles on my bike when I put mine on I had to clean the throttle body out from having the factory crank breathers routed into the intake.
Old May 13, 2015 | 11:21 PM
Jesse(J-Bird)James
1st Gear
adding exhaust and tuner just wanted to see if one was better then the other that's all thanks for the feed back
Old May 14, 2015 | 07:35 AM
Odin510's Avatar
Odin510
The difference between the 2 you referenced is basically looks. Gotta agree with 2500hd, the dk customs cleaners are cheaper, but if you get their external breather option, you'll give your motor clean, cooler air. This will increase engine longevity and give a few more hp as compared to a cleaner that routes crankcase air back into the air cleaner.
Old May 14, 2015 | 09:14 AM
TinCupChalice's Avatar
TinCupChalice
Another vote for DK Custom, venting the crankcase gasses to atmosphere is the best option, the EPA mandated method of routing the hot gas back into the throttle body is about making tree huggers happy, not keeping your engine in peak performance. This is the DK Custom 587 with smooth bobber cover using the breather bolts, a simple clean look that works... pretty, too ;D
Old May 14, 2015 | 03:36 PM
Warp Factor's Avatar
Warp Factor
Can we please stop with garbage like that? Every time someone repeats junk like that they heard on the internet somewhere, someone else repeats it as if it is true, and you get a big-ol' circlejerk!
The factory computer will self-adjust enough to put a Stage 1 back within stock specs. No, the engine won't "burn up".
Old May 14, 2015 | 04:44 PM
Dyna_Bagger85's Avatar
Dyna_Bagger85
Both are good choices. The SC heavy breather really acts the same as any other air cleaner. I learned the other day from an well established dyno shop that the forward facing AC doesn't have any ram air effect until you start reaching speeds of 135mph plus. Now how often do you stay cruising at that speed?
They explained an entire ratio of Air Force to actual power being gained. It was eye opening!!!
Old May 14, 2015 | 04:49 PM
soft 02's Avatar
soft 02
Or you stick it another 2 feet forward. Like was said. Its just for looks.
