Air Intake question
Old May 14, 2015 | 04:54 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Originally Posted by Warp Factor
Can we please stop with garbage like that? Every time someone repeats junk like that they heard on the internet somewhere, someone else repeats it as if it is true, and you get a big-ol' circlejerk!
The factory computer will self-adjust enough to put a Stage 1 back within stock specs. No, the engine won't "burn up".
The factory ECM has the ability to re-adjust to + or - 3% and no more. Go right ahead and run your bike on the far side of lean and when it takes a **** come back and complain about it!
Old May 14, 2015 | 10:25 PM
BigDogIdaho's Avatar
BigDogIdaho
I've got another vote for DK. I too had to clean my throttle body cause of the oil. No bueno.
I would throw a reflash on it. If for nothing else just that little boost of power it gives you. Bikes are lean from the factory. I'm not getting into the burn up or not **** ing match...
Old May 15, 2015 | 03:57 AM
Warp Factor's Avatar
Warp Factor
Wrong. It needs to be able to adjust about 20% just to accommodate air density changes caused by temperature changes. And that doesn't even include altitude changes. For example, air becomes about 15% more dense when moving from a 4000 foot altitude to sea level.
One of my stage one bikes without tuning was checked on a dyno, and it was not running lean. And Iron Horse Magazine has done a number of stage one type installs, checked on a dyno, and concluded that tuning wasn't needed.
RNDROB
Jul 11, 2017 06:51 PM
murdered1200
Jul 2, 2012 10:11 AM
towbyl
13
Jan 24, 2010 01:36 PM
chunks
Jun 17, 2009 01:31 PM
Thet
Mar 13, 2009 08:06 PM
