2006 Dyna Street Bob Torque specs
I have a friend that has the bike and she is worried that her ex husband has sabotaged her bike and I want to check everything on her bike before she rides it. I would hate to have anything happen to her. I do all the work on my own bike but I do not and she does not have a service manual for her bike.
Any help would be appreciated.
Critical Fasteners:
Hand Controls-Upper & Lower switch housings = 35-45 in lbs
Clutch lever handlebar clamp = 70-80 in lbs
Master cylinder handlebar clamp = 70-80 in lbs
Brakes:
Banjo bolts = 17-22 ft lbs
Lower brake caliper mounting pin = 28-38 ft lbs
Brake disc screws, front = 16-24 ft lbs
Brake disc screws, rear = 30-45 ft lbs
Resorvoir screws = 6-8 in lbs
Rear master cylinder mounting nut = 40-50 in lbs
Axle nuts:
Front axle = 50-55 ft lbs
Rear axle = 60-65 ft lbs
Front fork/handlebars:
Lower fork pinch bolts = 30-35 ft lbs
Slider bolts = 10-14 ft lbs
Upper bracket pinch bolts = 30-35 ft lbs
Handlebar clamp mounting screw = 70-80 in lbs
Riser clamp screws = 12-18 ft lbs
Riser lock nuts = 30-40 ft lbs
Critical Fasteners:
Brakes:
Axle nuts:
