grind tab for new pegs or what?
Old May 29, 2015 | 11:34 AM
slyedog's Avatar
slyedog
Default grind tab for new pegs or what?
Installing my new pegs and I notice that there is some little stop tabs that are preventing the peg from fully folding back. They stay where they are fine but just don't fold all the way back like they should. I can either reshape the peg to go around the tab or grind off the tab in the peg mount. What has anyone done? I usually ride with rear pegs up unless I have a passenger.
tab
max able to be folded in
view from inside
contact point
Old May 29, 2015 | 12:34 PM
blueangel73's Avatar
blueangel73
Are they in your way when folded up as far as they will go? If not, leave it be unless its a personal taste type thing. If the are, use a file and shave it down.
Old May 29, 2015 | 01:07 PM
slyedog's Avatar
slyedog
I talked to figure machine. They are going to machine some new swivels to the piece that I milled down. They didn't look right nor want to stay up without excessive force on the bolt to where I could hardly move them. These tabs either aren't that common or no one cares how their pegs sit?
Old May 29, 2015 | 01:27 PM
Jesse_81's Avatar
Jesse_81
I been meaning to grind my stops off as well. Just haven't gotten around to it yet. They're stupid, ugly, and useless.
Old May 29, 2015 | 03:38 PM
Tat2u's Avatar
Tat2u
My mounts have the stops but the kurykyn pegs are shaped to allow them to fold right up out of the way like you want.
Old May 29, 2015 | 03:53 PM
Dyna_Dave's Avatar
Dyna_Dave
Can't help you, but I CAN watch your avatar all day.
Old May 29, 2015 | 06:25 PM
XFXDX's Avatar
XFXDX
Why are they there?
Old May 29, 2015 | 10:07 PM
BigDogIdaho's Avatar
BigDogIdaho
I had the stupid tabs on my pegs from Drag Specialties. The only thing that saves me is they are front pegs so they don't need folded up.
Old May 30, 2015 | 01:08 AM
loopie's Avatar
loopie
did you spot the rear cylinder isn't letting the exhaust gasses out
Old May 30, 2015 | 01:36 AM
slyedog's Avatar
slyedog
You are Loopie. Look closer. Stare at it a while. Allow yourself to be consumed by it. The exhaust port has a grey spot right before the flame leaves the pipe on both cylinders.
