92 FXDC
Old Sep 18, 2005 | 09:20 PM
Robert's Avatar
Robert
1st Gear
Default 92 FXDC
I have a 92 fxdc and 2 months a go I noticed I did not have my rear brake light working. I checked the bulb and it was ok so I replaced the pressure switch with an acel aftermkt. one. Now its not working again and front brake light works fine. Recon I got a bad pressure switch and should I get one from the dealer this time?? I have a fobia about getting rear ended dontya know.[X(]
Old Sep 18, 2005 | 11:19 PM
dragsta's Avatar
dragsta
Default RE: 92 FXDC
I recently had some really funky electrical stuff happening. It was a corroded fuse. It seems that every time I wash my bike, water drains down over the fuses causing corrosion on the contacts. Pull your fuses and replace the ones with corroded contacts, then waterproof them with a plastic bag and tape if necessary before you put the cover back on.
Old Sep 19, 2005 | 12:28 AM
Robert's Avatar
Robert
1st Gear
Default RE: 92 FXDC
Thanks brother I will ck. that out for sure!!
Mikeinaz
Jul 15, 2018 10:39 PM
Fsellaro
Mar 31, 2010 07:53 PM
edfromptowne
Electrical/Lighting/Alarm
Nov 5, 2009 07:00 PM
Beeracuda
Jul 24, 2006 05:58 PM
dert
Sep 12, 2005 11:06 AM
