Jacking... um yeah
Old May 1, 2007 | 01:33 PM
cadillac's Avatar
cadillac
Default RE: Jacking... um yeah
dont forget...if you put 2x6's under the tires and plan on putting the bike on its jiffy stand, put the same thickness block under the stand too. Otherwise the bike may fall over.
Bob
Old May 1, 2007 | 04:02 PM
footpeg's Avatar
footpeg
I have the Sears Red and black atv jack. If you put a 2x4 under the kick stand with the bike on the ground, not on 2x6's, then you can justslide the jack under the bike from the right side of the bike with plenty of clearence. You then put a 1" piece of wood under the left side rear frame railto level the rear of the bike (because of the 1" metal rail underthe right side frame rail used as anoil pan protector)and jack away. Make sure that the wood is 1" not a 3/4" piece. You may need touse a 1 x and a 1/4" piece on top of thatin order to equal 1 real inch in height because a 1x3 is really 3/4" by 2 3/4".
Old May 1, 2007 | 10:35 PM
SmoothRider's Avatar
SmoothRider
ORIGINAL: Timmer
HD Part # 98965-99 $21.95.
Thanks for the heads up on these. I went that day and got them. While my bike is sturdy on the jack, for the $22.00 these cost it will be extra piece of mind.
Old May 2, 2007 | 02:55 AM
wlbowers's Avatar
wlbowers
ORIGINAL: Sabaka454
I mean jacking up your bike! I'm looking at my wide glide and was going to jack it up with my Craftsman motorcycle/atv jack and I don't see how you can possibly jack this thing up without hitting the kick stand or oil pan. Anyone have any good methods for jacking? lol
The sears yellow jack is a lower profile than the red one. I have a bad back so I was cautious the first time I did this. I bought the Harley Dyna blocks for one reason only. They slip onto the frame and stay there.
This works for me. BE CAREFUL.
I put the blocks on the frame in the position shown on the sheet.
I get the jack ready to roll under the frame, no extention platforms on the jack.
The block on the left rear I pull on the bottom of it till the bottom is pointed at a 45 degree angle away from the Dyna.
I then sit and pull up the kick stand. Then I lean over and push down the block. Very Carefully.
Now I grab the jack handle and roll the jack under.
I give it a couple of pumps till it makes contact.
Once it makes contact I lean over to see if the jack is positioned on the blocks. If it is.
Then a few pumps and me and the Dyna go up.
If not reposition the jack and try again.
Old May 2, 2007 | 06:13 AM
Rauzer's Avatar
Rauzer
I need to get one of those. My local Sears only has a black jack. Did they stop making the yellow ones?? Good information guys!!
Rengnath
Feb 10, 2018 01:21 PM
cst010
Jun 19, 2009 06:48 AM
dFREDb
May 31, 2009 06:41 AM
JBaker421
May 30, 2007 03:40 AM
Cruiser 1970
Oct 3, 2006 04:04 PM
