Broke Down
Old Jun 23, 2015 | 04:39 PM
Wireguided's Avatar
Wireguided
Default Broke Down
Hello everyone,
iam needing some input today as the bike broke down far from home.
I went to start it and it turned over 2 twice but did not start.
things I know ....
ignition is good
battery has 13v
kill switch is working.
auxillary on ignition works ,
but when turned to the right
no power anywhere at all.
fuses are good and so Is main .
any ideas ?
Old Jun 23, 2015 | 04:58 PM
stilup's Avatar
stilup
Relays?
Old Jun 23, 2015 | 05:14 PM
Wireguided's Avatar
Wireguided
Maybe I thought that too need to find a place and try that.
disasembelled ignition its ok.
still only power in aux only
Old Jun 23, 2015 | 06:21 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Bad ignition switch. They do wear out sometimes.
Old Jun 23, 2015 | 06:26 PM
target64's Avatar
target64
at terminal A the red/black wire at the back of the ignition switch with it turned on is 12 volts present ? you say there is only power in the aux position. that is terminal c the red/gray wire. if there is no power coming out on red/black wire needs a switch.
Old Jun 23, 2015 | 07:29 PM
Wireguided's Avatar
Wireguided
Switch has power , battery has bad voltage drop.... off to get one now so ill post later.
Old Jun 23, 2015 | 08:19 PM
Imold's Avatar
Imold
A battery with a shorted cell can do that, but I've also had a corroded ground wire do that. Passes enough current for a VOM to read, can even handle the lights sometimes, but everything dies when you try putting starter current on it. Sounds like you'll have a new battery before getting back on the forum - if that doesn't change the situation, try loosening and cleaning the other end of the battery ground wire.
coo1breeze
May 14, 2020 10:00 AM
ITOLUSO
Electrical/Lighting/Alarm
Jul 20, 2019 12:04 AM
steelpony16
Apr 10, 2015 03:53 PM
Uncle Scrooge
Jun 4, 2007 08:43 AM
calacha
Jan 11, 2007 11:35 AM
