check engine light
Old Apr 29, 2007 | 09:14 PM
indigenous's Avatar
indigenous
Default check engine light
installed pipes and pc111 on 06 bob and installed map problem is after check engine light goes out after initially coming on it comes back on about 8 seconds laterand goes back out after about 30 seconds whether bike is running or not is this normal with pc111
Old Apr 29, 2007 | 11:51 PM
soup48's Avatar
soup48
Default RE: check engine light
One question, do you have the 8 degree injectors or the 25 degrees. Thats all that I can guess.
Old Apr 29, 2007 | 11:55 PM
indigenous's Avatar
indigenous
25 injectors but one screamin eagle said using the 9 volt will set the code thanks
Old Apr 30, 2007 | 03:46 AM
sporty79's Avatar
sporty79
I had the same issue when I first installed my PCIII. I was never too worried about it since the light always went out after about 10 seconds, so I never looked into it. After a while it just stopped. I did use a 9 volt battery to load the map, so you may be onto something there...
HOGILAC
May 21, 2018 08:45 PM
hairbiker
Nov 17, 2008 06:23 AM
markymark
May 24, 2008 09:25 PM
Possum64
Feb 14, 2008 01:15 PM
lowleveldriver
Apr 2, 2006 07:06 AM
