Need Map
Old May 20, 2018 | 10:15 PM
HOGILAC's Avatar
HOGILAC
Default Need Map
What's up forum? I have an 03 Electra Glide Classic (Anni. Edition) w/211 SE CAMs, CFR Exhaust and True Duals w/ a PC5 currently running 15-027-199 and recently ran the 15-027-198. It runs great but in 5th gear it bogs down sometime and the check engine light comes on but then goes back off. Overall it runs great, any have this setup running a different Map? Please share any suggestions.
Old May 21, 2018 | 07:37 AM
Cygnusx51's Avatar
Cygnusx51
What error codes do you get since the check engine light is coming on? I’d think that should be looked into first before trying a new map.
Old May 21, 2018 | 10:01 AM
HOGILAC's Avatar
HOGILAC
no codes are stored...., light flashes and goes within a few min.
Old May 21, 2018 | 06:33 PM
EdwardK's Avatar
EdwardK
Are you sure? If the light came on, even for a second or two, it should have stored a code. Turn the bike on and watch the check engine light. Does it come on, go off, then come back on for a second or two before going off again? If so, you have a stored code. There are many threads here on how to read them then google the code to see what it is.
Old May 21, 2018 | 08:45 PM
HOGILAC's Avatar
HOGILAC
Thanks.., I checked the codes and went thru each one and they all say that they are CLR.
Eyespy
Jan 23, 2009 11:35 PM
hairbiker
Nov 17, 2008 06:23 AM
Possum64
Feb 14, 2008 01:15 PM
indigenous
Apr 30, 2007 03:46 AM
lowleveldriver
Apr 2, 2006 07:06 AM
