Ignition problem fxds 96
Old Jul 18, 2015 | 06:10 PM
Mike Scarlatti's Avatar
Mike Scarlatti
Stage I
Default Ignition problem fxds 96
I am not getting any spark. Changed the plugs, cables and ignition coil. Also their is a brand new battery in it as well. Going about 40 mph and it just shut off. It turns over but doesn't start. I have 12 volts dc at ignition coil going in. Nothing coming out
Old Jul 18, 2015 | 07:23 PM
apples402's Avatar
apples402
Post this in the EVO Classic forum...that being said there are a few things to consider on the ignition, stock? if so check wires coming from nose cone, may be frayed, or the connection on the other end should be behind circuit breaker panel. If these are fine then may be ignition module itself or the rotor cup (both are in nose cone if stock), if there are rivets in the cover it is likely to be stock. Do you have a service manual? There are a bunch of good experienced guys at the EVO forum, way way better than me.
RanHow
Ironhead
Sep 9, 2017 08:36 AM
Oldboy55
Electrical/Lighting/Alarm
Mar 25, 2014 03:33 PM
John1957
Shovelhead
Jul 22, 2012 03:08 PM
kpolak
Nov 24, 2010 08:51 AM
harleymark
Mar 4, 2009 08:32 PM
