Pipe Question
Old Aug 9, 2015 | 06:40 PM
Geoff's Avatar
Geoff
Default Pipe Question
I recently picked up a 2003 Low Rider. It has a stage one with a high flow air cleaner, rej-jetted carb and Cycle Shack pipes. The pipes are too loud. If I reinstall the stock pipes, will the bike run too rich? Will there be too much airflow?
Old Aug 9, 2015 | 07:09 PM
Nitro 54's Avatar
Nitro 54
You should be fine with the stock pipes.
Old Aug 9, 2015 | 07:36 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You'll be fine but it'll run like a turd.
Old Aug 9, 2015 | 09:30 PM
slyedog's Avatar
slyedog
Wear earplugs or look into a different slip on rather than running stock mufflers again. Cycle shacks are a cheaper muffler. Go better quality and some more baffle options will be out there.
Old Aug 10, 2015 | 09:00 AM
Geoff's Avatar
Geoff
Thanks for the replies.
I was just wondering how back pressure from stock pipes would affect the bike. If it doesn't run right, I'll re-jet.
I found a take-off exhaust on Craigslist for only $60. It was removed from a new bike with only 11 miles. It's a complete system, including headers, mufflers, heat shields, support bracket, clamps and hardware.
My '03 FXDL is a one-owner bike with 16k miles. It looks showroom new without a single blemish. Only problem is the previous owner never serviced it except for two motor oil (dino) changes. That's it. The guy looked at me funny when I asked if he did any other scheduled maintenance.
The bike needs tires, a complete tune-up, steering head greased and torqued, brake fluid flush, and fresh oil in 3 holes. I also want to replace the shocks with a pair of Progressive. These are higher priorities than slip-ons. I'll find some pipes at a Walneck's swap meet over the winter.
fredzep
Apr 17, 2014 01:33 PM
3illy
Apr 6, 2014 08:06 AM
Lumpy Schmidt
EVO
Sep 5, 2012 12:01 PM
NEW2HD
Apr 25, 2006 02:19 PM
brohrs
Nov 26, 2005 10:13 PM
