Need help!! Running issue
Old Aug 28, 2015 | 05:25 PM
Lowdyna89's Avatar
Lowdyna89
3rd Gear
Default Need help!! Running issue
2005 dyna low rider 88 with 95kit , thunder header , power commander, EFI.Just changed my IAC valve and all new oils. can any one give me some insight on why my bike sounds like this and also why my rpms are at zero? When I start the bike every thing is all good it has been happening when I go on a longer ride and the bike starts to get hot is when it starts acting up. The rpms drop but the bike is still idling fine not wanting to die out. The bike has a slight ticking noise but not all the time? Possible exhaust leak? Any help will do
Old Aug 28, 2015 | 06:56 PM
dudshep31's Avatar
dudshep31
you having any issues maintaining speed or with back firing?
Old Aug 28, 2015 | 07:14 PM
Lowdyna89's Avatar
Lowdyna89
3rd Gear
Nope runs smooth on the freeway and around town the rpms drop when I pull the clutch in and come to a stop
Old Aug 28, 2015 | 07:20 PM
dudshep31's Avatar
dudshep31
So your actual rpm's aren't dropping out? Just what the gauge is showing?
Old Aug 28, 2015 | 07:26 PM
Lowdyna89's Avatar
Lowdyna89
3rd Gear
Correct and I have heard that my gauge could just be going out I'm more concerned about the noise coming from the motor
Old Aug 29, 2015 | 09:47 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Unplug the power commander and go back to stock connection. Does the tach indicate rpm's? Reinstall the power commander, does problem still exist? If the tach work stock then the PC has a problem getting the signal to the tach.
Ultra61
Jun 4, 2017 08:51 PM
Therealrsp Therealrsp Therealrsp
Mar 11, 2016 06:29 PM
Ripcurl
Engine Mechanical Topics
Jun 16, 2014 04:49 PM
Naz_Man
Apr 8, 2013 07:18 PM
jeffwest5599
Jun 30, 2010 12:33 PM
