Fl vied 10 install
Old 09-29-2015, 10:01 PM
emperor wurm's Avatar
emperor wurm
emperor wurm is offline
Default Fl vied 10 install
I installed my vied's tonight they work great no more decel pop. My issue is how to bundle the front vied. Right now I have the connector and excess wiring tie wrapped to the frame. I don't know how I feel about this.....where/how did you tuck away your connector and excess wiring? Thanks
Old 09-29-2015, 10:15 PM
ChromeBlows's Avatar
ChromeBlows
ChromeBlows is offline
I used them on my bagger and it enhanced the throttle response though it knocked my milage from 49 to 44 mpg.You experience the same here?
Old 09-29-2015, 11:26 PM
MRFREEZE57's Avatar
MRFREEZE57
MRFREEZE57 is online now
Received 4,288 Likes on 1,969 Posts
I just bundled mine behind the O2 sensor plug, or your way sounds ok, just do not put where can get extremely wet in case you end up in a rainstorm.
Old 10-12-2015, 01:44 PM
warprints's Avatar
warprints
warprints is offline
On my FXDF I zip tied it behind the plate that is in front of the oil filter. Have mine set at 75% - fantastic improvement over stock. Will check mileage on the next tank or two and let you know how fuel mileage does.
Old 10-12-2015, 02:11 PM
emperor wurm
Yeah, Im at 75 as well, went from average 180 miles a tank to about 160....
Old 10-12-2015, 02:13 PM
O-Town D's Avatar
O-Town D
O-Town D is offline
Two reasons why that could happen: by function, the XIED/VIEDs as well as other tuners 'adjust' the ECM to run richer, affecting MPG to some degree. The other reason is more subjective: with a better running motor the urge to twist the throttle is harder to resist, which also shows up in slightly reduced MPG. But the small trade-off is well worth it. Just enjoy it, and ride safe!
Old 10-12-2015, 09:00 PM
warprints's Avatar
warprints
I'm certainly expecting lower mileage due to the fun factor of goosing the throttle more than I did before.
Old 10-12-2015, 10:32 PM
ChromeBlows
when I'm on my own I twist the **** outta that wick and I surely don't get near 44 mpg,it's more like 20-25 then.I'm talking cruising,doing road captain duty.REsisting the overwhelming desire to have your facial hair removed by wind!I guess I already knew the answer though since I recall that the reason it keeps the jugs cooler is that it's dumping more gas in the chamber causing a natural cooling effect.Just wondered for comparisons sake.
EdandGrace
02-24-2013 08:01 PM
man4mopar
05-05-2011 05:18 PM
buckmc
02-20-2011 08:32 PM
lencap
07-31-2010 08:34 PM
Scorpio49
10-19-2008 07:30 PM
Quick Reply: Fl vied 10 install
