Hey guys,
I've got a 2008 Street Bob with 16'' apes and extended cables. I bought the bike used with the previously mentioned set up. However, there is a lot of grittiness and tension in the throttle. It is very hard to turn and it sluggishly snaps back into place. I've tried adjusting the cables to no result. Is it because there is so much extra cable or a different problem?
so you just had to replace them? How could you tell?
how could i tell? because they were acting like yours... and when i had my guy doing some other work he discovered the frays and replaced the cables... if you do not know how to replace cables have bike mechanic do it... they are rather important....
Try lubing the cables, if that doesn't work you may have some frays in there... change the cables if that's the case
And when you have the cables off, remove the twist grip, clean everything inside and out, put some dry graphite lune inside and out before re-installing cables. Do it all at once
