quick tire question
Old May 6, 2007 | 02:31 AM
nkauf21's Avatar
nkauf21
Default quick tire question
found a good deal on a dunlop 180 tire which is the same tire used in the 180 kits. the info sticker on the tire says tubeless. But with spoked wheels you need a tube so will i be able to use this tire and just put a tube in it?
Old May 6, 2007 | 12:28 PM
soup48's Avatar
soup48
Default RE: quick tire question
I think any tire is able be tube type. The tire has that on it to say the tire has been made to seat the rim tight with no leaks in that area.
Old May 6, 2007 | 12:45 PM
jt1965's Avatar
jt1965
The tire is not a radial tire so as I understand it, the tire will be fine.
Old May 6, 2007 | 01:50 PM
piniongear's Avatar
piniongear
Short answer is yes.
Old May 6, 2007 | 02:10 PM
nkauf21's Avatar
nkauf21
One more questions, I keep hearing that the tire will fit withoout using the wide tire kit parts. Is that true? What is actually included in the kit? It will be for an '06 Street Bob
Old May 6, 2007 | 03:02 PM
piniongear's Avatar
piniongear
I have no idea what the wide tire kit is about.
All you need is a rim, spokes and a tire/tube. Keep it simple.
Old May 6, 2007 | 03:13 PM
Ganooch's Avatar
Ganooch
I have the Screaming Eagle 180 on my WG tubeless with spokes. You will be fine.
Old May 6, 2007 | 04:58 PM
Oilslick's Avatar
Oilslick
ORIGINAL: L0W R1D3R
Let me get this straight. You are running this tyre tubeless on a spoked (laced) rim?
Oldman Bagger
Wheels/Tires
May 24, 2021 06:27 PM
NightHunter
Wheels/Tires
Jul 17, 2012 08:36 PM
hduc2005
Aug 31, 2006 06:28 PM
Tx_Outlaw
Jul 17, 2006 12:58 AM
mndemohead
Oct 4, 2005 09:27 AM
