Brembo calipers
Howard at Motorcycle Metal is the guru on this subject ... he introduced himself above in his usual manner.
The Fatbob's and new Lowrider's have factory dual discs so you should be able to use all of the parts off of one of them to complete your system... and I do seem to recall that the calibers you bought will bolt right up to the lowers of the Dyna's. That means you will need lines, master-cylinder, the discs, the right lower..
Dose your stock hub have the holes in it to bolt up a right disc? If not you will need a wheel.
I, as in this case, informed the OP that I have or there is previous information already posted on this subject matter. In this case it was extensively covered by me. I support this forum and very rarely advertise which is expensive for those who do not take this into account (maybe 3 or 4 times in since joining this forum back in (I think 2005 before the site crash that wiped out all data but I am not that far off) the near beginning. I post only solutions to problems to help out others in subject matter I know about unlike many who have absolutely no idea what they are talking about. My volunteered time is just that, however, my time is not worthless to me. I already know the answer to the problems I post on because I do it first and know what I am talking about.
OP, either use your search function or not as it is here because my in depth explanation (several versions) was posted multiple times. I am in the process of creating several new products (over the winter) that will market including but not limited to wheel mounted fully floating 320mm race capable rotors, OEM Brembo adapters for the 2000~current FLT & FLST, and lastly for the FXD for both single & dual sided applications. I am not going to manufacture caliper adapter(s) for the FXD & 300mm rotors.
If any of the above posted information in this post was correct for the OP's application than there would be no need for me to do so. OP, the information is there and I say again
