Oil temp dipstick
Old Dec 23, 2015 | 01:02 AM
  #31
rogersachs's Avatar
rogersachs
Smile
Originally Posted by dohadex
I am one of the rare ones who've had good luck with my HD oil temp dipstick. I bought mine in 2009, and just replaced the battery last month. I know this is the exception though.
I do nothing different than yall do...I press the button after a ride to check the oil temp and say...oh ****! My oil is running hot!
I do the same. Usually it runs 230-250F and I say the same. . So far it is running well after 6 months.
Roger
Old Dec 23, 2015 | 07:05 AM
  #32
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Originally Posted by 13dino
Two of the H-D oil digitals went out as fast as put in when bike was new. Cooled the motor by a tune which should no longer burn out the high heat sensitive H-D screw-in electronic sender.
But will let the 3rd warranty replacement stay unused in its plastic on the shelf due to all the thieves wanting an easy quick pickin while your parked doing your thing down here. What a friken zoo it's become down here!
Where at in particular Dino? I have visited my brother in law in Tampa a couple of times in the past few years and for sure there are a lot of people down there. However the roads make it a whole lot pleasurable to ride compared to ours here in Okie-homer.
Old Dec 23, 2015 | 08:35 AM
  #33
pab3rd's Avatar
pab3rd
I had an HD Oil temp Dipstick about 6 months and heat from the exhaust melted it. So much for that item.
Old Dec 23, 2015 | 09:24 AM
  #34
cvaria's Avatar
cvaria
the lcd dipsticks are terrible. mine was basically DOA. i have no idea why there is no analog gauge available from hd. why do we need to pay JES $160 for a gauge that make changing the oil harder?
why is it that JES managed to do, independently, what the MoCo could not do?
i like my power vision but i don't want it on my bike all the time (sooner or later, i'll slip up and a thief will run off with it)
i want a decent temp gauge. has anyone fitted an touring temp guage to their bars?
update: looks like it's possible with HD parts 70900283 , 26165-07, and some sort of mount.
Old Dec 23, 2015 | 09:29 AM
  #35
cvaria's Avatar
cvaria
Originally Posted by Jeff's 1st Harley
Ride it and keep it in the wind and don't worry about it. Just use Mobil 1 syn or any good synthetic and ride on, I mean what are you gonna do stop and push it.
this does not hold water. if your engine is cooking the oil to the point of viscosity breakdown, you'll be changing the oil more frequently or tearing apart your engine. your approach says, "ride it and ignore temps until something breaks." unacceptable. criminal negligence
Old Dec 23, 2015 | 09:51 AM
  #36
schlacker's Avatar
schlacker
I use it from time to time, if it's an exceptionally hot day & I'm expecting to be traffic, something like that. It's good enough to give me an idea of what's going on.
Old Dec 23, 2015 | 09:58 AM
  #37
skid_pimp's Avatar
skid_pimp
I've had two digital gauges from Harley and the first one is still going strong at nearly 8 years and the 2nd is over 4 yrs old, both on Softails. And I've also had several analog Harley dipsticks on Softails and not had problems. I think the dynamic location is causing some of y'alls issues. You could consider running a sensor on your oil cooler adapter plates, and a simple lcd or led display on the bars or fairings...
Old Dec 23, 2015 | 10:09 AM
  #38
cvaria's Avatar
cvaria
Originally Posted by skid_pimp
...You could consider running a sensor on your oil cooler adapter plates, and a simple lcd or led display on the bars or fairings...
that's exactly what i came up with above. the hd parts are crude. there must be a better bet out there using the sensor/sender method
Old Dec 26, 2015 | 11:47 PM
  #39
13dino's Avatar
13dino
@Jeff, more so start having theft problems on east side beginning from and getting stronger as one goes south is from the Palm Beaches and down to the Keys end.
Peace
Old Dec 29, 2015 | 01:52 AM
  #40
103 sedona orange's Avatar
103 sedona orange
I purchased one. I don't how accurate the temps were. As it got older I didn't trust the oil level. It took a **** way to soon & into the trash can it went. You need to ask your self, self do your really want to know how hot your oil gets? lol.
BigDaddyMike
Dec 25, 2020 11:34 PM
Big Dave
Aug 11, 2016 06:11 AM
raybaby
Mar 2, 2010 01:28 PM
ms3300
Nov 10, 2008 12:26 PM
RandyD123
May 17, 2006 11:08 AM
