XXXXXX Glide front ends
(the triple part was for fun)
"Using basic math skill 29 in the neck and 29 overall says 0 difference."
You have to get accurate information first
All those words in one hand vs a physical set of trees in mine ....hmm
Btw, I said they were negative...FastHarley just gave it a value
Sorry OP, but there some good info in this
Feels like i'm playing poker and i have a Royal Flush
Op, take the information as you please, trust it if you want. All I can say is that it's on the internet, so it isn't trust worthy regardless of who provides it.
I have physical access, so I can verify.
If your talking about yourself... well, you shouldn't make contradictory statements if you can't verify or until you do verify. Questions and discussions are good
Bold contradictory statements without any back-up...Not Good
I was trying to also get an understanding of how HD says the neck is raked at 29 degrees on the frame and the steering rake is also at 29 degrees after the trees are installed. The rake having a negative one degree, as you guys say you have physically confirmed, would suggest that the steering rake would be at 28 degrees, one degree under the necks 29 degree rake or the necks rake is actually 30 degrees and the negative one degree brings it to the steering rake of 29 degrees. Maybe you can tell me which one is correct so I will know the correct answer.
Yes, I could have waited until I got home, pulled the fairing, all of its mounting hardware and headlight off my bike, put a magnetic angle finder on the neck and then the legs to compare the the actual angle difference and then given the OP an actual answer, but after almost a month of crappy weather, I decided to ride instead of ripping my bike apart.
Anyways, I am sure the OP has got the info he was after and hopefully it helps him out.
OP, I am sorry I tried to help, I was only trying to provide you an answer and provide where I got the answer from so you could verify it yourself. However, it's apparent that.those resources aren't reliable sources, well according to other forum members a least. Man, I sure hope you don't ever run into any electrical issues, those electrical schematics are provided by the same unreliable sources, it would really suck to have to wait for someone to tear their bike apart trying to get you a physically reliable answer.
Just based on my experience with riding a FXDWG and FXDL and FXD, the Low Rider and Wide Glide just don't snap in and out of tight curves like the Super Glide. What I experienced is that they tend to drift up and outside in curves more than my SG (it tends to drift down inside curves) and they are lower to the road and tend to scrape more when you really lean in a tight curve, (that'll get your attention when you are not expecting it!) and they are a little more cumbersome with slow maneuvering in parking lots, etc...but they do look Old-School sexy.
Flex an torsion, the size of the tubes and their width to each other,, there's a lot more your missing if you think rake is the only variable that effects a factory set-up.
The 2006 and up Wide Glides have a 34* degree neck and a 2* triple clamp. The other 2006 and up Dyna's have a 29* neck and 0* triple clamps, except the Low Riders which have 1 1/2* triple clamps. Also Harley's web site "only" lists the degrees of rake in the neck......"Rake (steering head) (deg)".
I'm not sure about the Switchback it is listed on Harley Davidson's website as Rake (steering head) (deg) 29.9 http://www.harley-davidson.com/en_US...ck.html#!specs
DYNA 2006 and up:
Street Bob has a 29* frame neck with 0* triple trees
Fat Bob has a 29* frame neck with 0* triple trees
Low Rider has a 29* frame neck with 1 1/2* triple trees
Wide Glide has a 34* frame neck with 2* triple trees
Switchback has a 29.9* frame neck with ??* triple trees
Mid Glide to Wide Glide/Fat Bob width = 1 1/2" wider
Some info here:
http://www.totalmotorcycle.com/motor...y-Davidson.htm
