Clutch Upgrade
I have a 2014 Fat Bob. And i love the bike. But i HATE the stock clutch. Coming from the Dirt/Street bike world. Im used to a good solid clutch engagement. This one, even after adjusting it per the manual just seems weak.
It doesnt really seem to slip persaym but if i slam a gear at WOT it just doesnt seem to grab the next gear really hard.
Im thinking maybe the clutch spring will help with this? Or is it fine and i just need to get used to it?
Thanks
I have a couple bikes and each clutch is different. I can still WOT on all my bikes without hesitation and have full confidence. You'll adapt after more time on the bike.
But the hard shifting it just doesnt seem to like. But again... its a crusier so i just need to remember that.
I have only done this once or twice, but if i "no lift shift" Grab clutch, kick up and let go really quickly it seems to slip everywhere.
But again im sure its my style. Thank you for the reply
The stock clutch pack is set up for 70-maybe 100 hp. When it gets hot or is put to hard work like yours, it will slip.
A complete Bandit, Barnett, or Rivera aftermarket clutch will solve this, as they have a lot more friction surface.
You could also upgrade your stock clutch basket with an aftermarket clutch pack from one of these companies.
After 6500 hard miles it might be time...
And this is why im asking.
Ive only ever replaced clutches on my dirt bikes. Similar, but not the same. Im not worried about performing the work. I am more than capable
But im looking at Barnett's site and i could use a recommendation on what set to buy.
I see Kevlar, Carbon Fiber, 9 friction plate, 10 friction plate, diaphragm spring, etc.
Can i get a recommendation on what kit to look into/possibly purchase? My engine is going to remain stock internally. Just the stage 1 stuff i currently have
While in there, I would also replace the pack with a fresh one from Barnett or others.
Night and day difference, and you should be able to hammer it all day...
If you replace the clutch pack and want more "grab" get a +1 kit, this will add more friction area. I used to run the Alto +1, but others like Barnett have theirs too.
