Which TSSM do I need (Security)
Old Apr 3, 2016 | 05:46 PM
Vic Williams's Avatar
Vic Williams
Default Which TSSM do I need (Security)
I have a 2001 Dyna Low Rider. The TSSM is shot. The one I took out says.
H/D P/N 68922-00
Ive seen 68922-00
68922-00A
68922-00B
68922-00C
68922-00D
Can I use any of those?
Old Apr 3, 2016 | 05:53 PM
14GuineaPig's Avatar
14GuineaPig
You should be able to ... the letter designation is a revision number.
You can lookup part numbers here to see if a number has been changed.
If you use "Ctrl" & "F" is should open a "Find search box" to lookup a number.
https://shop.newcastlehd.com/sites/d...on_numbers.pdf
Old Apr 3, 2016 | 06:27 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
A dealer may give you a more definitive answer maybe your VIN number will be the deciding factor. Typically as HD parts are upgraded an alpha suffix is added to the part number.
No Tyme
Jul 25, 2018 08:34 AM
Jeffrey Long
Electrical/Lighting/Alarm
Feb 25, 2017 11:40 PM
Hades02
Mar 11, 2016 01:06 AM
Puppy
Flathead
Jan 11, 2014 08:54 PM
jmb79
Aug 24, 2013 11:39 AM
