Differences Between Model Years?
Old May 13, 2016 | 10:19 AM
multihdrdr's Avatar
multihdrdr
Originally Posted by fxdli
Order back rests for the two bikes, perhaps that will change your thinking?
He has a 05 FXDL I have 04 FXDLI
I think...No, I know the difference is because of the "I"
It's "just the facts, ma'am"
Old May 13, 2016 | 10:20 AM
cggorman's Avatar
cggorman
Originally Posted by Super Glidester
I put saddlebags from an 01 Wide Glide on my 05 Super Glide. Bolted up no problem, now getting the Detachable Sissy bar side plates to work along with them without relocating the turn signals was a challenge. I have always thought parts interchange from 99-05?
Within the same model, or across the entire Dyna line? Seats definitely don't. The attachement points on the frame changed in '04. They went from separate bent metal hoops for the front seat tab and rear tank tabs to the integrated tank/seat "barrel". The later style is much cleaner looking and required quite a bit less welding.
Besides that, there is also a pretty significant difference between the WG frame and front end than the rest of the Dynas. (oh, and fenders. And tank, I think. Maybe console. And wiring harness... Dammit, just consider the WG a unique bundle of parts. PITA!)
Old May 13, 2016 | 10:24 AM
PapaThiele's Avatar
PapaThiele
I have a 2004 an my Bud has a 05. 04 Backrest won't work on his, mounting holes different.
Damn MoCo Bastards!
Old May 13, 2016 | 12:34 PM
JayStronghawk's Avatar
JayStronghawk
Can't verify this for positive sure but my Indy told me today that my 05 Dyna Front Axle is 1" and the Rear is 3/4" .. Will find out for sure soon enough ..
Old May 13, 2016 | 12:40 PM
multihdrdr's Avatar
multihdrdr
So is the 2004...made the change to 1" (front) in 2004 (except FXDWG), then to 25mm in 2008.
Old May 13, 2016 | 02:10 PM
JK_Showtime's Avatar
JK_Showtime
Definitely having a 04 or 05 can be difficult at times for buying parts. The most difficult thing is that it is almost impossible at times to find a used seat for my 05 on somewhere like craigslist. I have an 05 FXDCi which was the fuel injected super glide custom.
Old May 13, 2016 | 02:17 PM
cggorman's Avatar
cggorman
Might be worth trying a seat from any other dyna between 04-05. I was told the 99 WG used a different seat than the rest of the bikes. The LePera Silhouette I bought fits it just fine but isn't listed in the compatibility list.
Old May 13, 2016 | 03:26 PM
fxdli's Avatar
fxdli
Ok Boys an Girls as they say a pictures worth a 1,000 words. So 2 pictures must be worth a total of 2,000 words. I am sure you will use all 2,000 words.
Differences Between Model Years?-mounting-holes-001.jpg 2005 FXDL with a 5" spread C/C
Differences Between Model Years?-mounting-holes-002.jpg 2004 FXDLI with a 9.5" spread C/C
Old May 13, 2016 | 03:36 PM
multihdrdr's Avatar
multihdrdr
Attachment 471980 2005 FXDL with a 5" spread C/C
Attachment 471981 2004 FXDLI with a 9.5" spread C/C
Here's a picture...
Old May 13, 2016 | 03:45 PM
fxdli's Avatar
fxdli
Ok so you ride the short bus. I get!
