Heat Sheild Problem.
Old May 16, 2007 | 04:49 AM
DiabloBlanco's Avatar
DiabloBlanco
Default Heat Sheild Problem.
The heat shield on my Vance and Hines Big Radius pipe keeps coming loose. Had the problem about a week ago tightened it up about 200 or so miles later it came loose again. I tightened the twoclamps as tight as they go but still somehow it comes loose. Just wondering if anyone else has had similar problems in the past and the fix they made. It was never a problem till I took the baffles out. Thanks
[IMG]local://upfiles/31082/FCD0C00E6A8345DFA6670000B2807F96.jpg[/IMG]
Old May 16, 2007 | 07:13 PM
JayFromPa's Avatar
JayFromPa
Default RE: Heat Sheild Problem.
It may or may not work, but have you considered a small amount of Loctite on the clamp threads?
Old May 16, 2007 | 10:45 PM
soup48's Avatar
soup48
My brother had the same problem and he changed the clamps to regular hose clamps.He has not said anything about it since.
Old May 17, 2007 | 05:02 AM
DiabloBlanco
Thanks for the ideas guys. Jay I think I am gonna try and throw the locktite on tommorow. I thought of that also but was not sure if that was gonna create any kind of lock in the clamps themselves.
Thanks again
Ken
Old May 17, 2007 | 10:28 PM
JayFromPa's Avatar
JayFromPa
Even if it did cause any type of issue like that, it's not like you couldn't just snip them off with some tin snips and try different clamps.
Good Luck.
Old May 18, 2007 | 01:28 AM
05 Wd Gld's Avatar
05 Wd Gld
I had a problem with a couple of clamps on my BSS pipes. Just installed new hose clamps and didn't over tighten them. No more problems.
cliffyleft
Oct 28, 2021 07:21 PM
drunkenmonke
Sep 1, 2013 09:24 PM
kmnjr
Sep 3, 2011 10:55 PM
Spanish Flyer
Oct 27, 2007 01:12 PM
relli
May 28, 2007 05:16 PM
