Riser extensions, wouuld you use them?
Old Apr 10, 2016 | 06:15 PM
Mchad's Avatar
Mchad
Default Riser extensions, wouuld you use them?
I want to "raise the bar" on my FXDL-S and am having a bitch of a time finding 8" risers for a 1.25" bar. I came across riser extensions, which would be silly easy to install. But I am not sure how I feel about them, and using 2" longer bolts.
https://www.denniskirk.com/la-choppe...prd/599404.sku
Anyone use these?
Old Apr 10, 2016 | 06:20 PM
04FXDI's Avatar
04FXDI
Doesn't Wild One Chubbys make what you're looking for in black?
Old Apr 10, 2016 | 06:32 PM
Mchad's Avatar
Mchad
They do, but I actually like the drag bar that comes with the S, I just need it up a couple more inches... I'd prefer to use solid risers, but I'll be damned if i can find 8" risers for a 1.25" bar...
Old Apr 10, 2016 | 06:34 PM
WVDevil's Avatar
WVDevil
I've got 1.5" extensions, no trouble at all.
Old Apr 10, 2016 | 07:27 PM
Fireguy88's Avatar
Fireguy88
I have the LA Choppers 1.5 inch extensions. Only have about 300 miles with them on but no problems yet. It's a cheaper option than getting taller bars you may not like. Also, when did you get the LRS? Sharp man! Congrats!
Old Apr 10, 2016 | 08:09 PM
Northbound Southerner's Avatar
Lookup spacer Jim. They are awesome. Very solid and well made.
Old Apr 10, 2016 | 08:22 PM
HarleyBob52's Avatar
HarleyBob52
A little more help on finding this please... I have been looking for riser extensions also
Old Apr 10, 2016 | 08:39 PM
Switchback12's Avatar
Switchback12
DK customs makes some, have had them on my wife's Iron for two years and about 20k miles, no worries.
Old Apr 10, 2016 | 08:41 PM
rgr357's Avatar
rgr357
I put a set of 2" DK Custome Fat risers on about 2 weeks ago as seen here.
http://www.dkcustomproducts.com/Hand...r-Kits_c16.htm
Just fit on my wide glide without lengenthing any cables. Although I did have to remove one of the cable retainers to let the front brake line have some more room.
Not real big on the idea of a spacer in there but they feel just as solid as they did before. I was trying to determine what to do with my bar as they just didnt fit me & didnt want to go with a full riser setup just to find out I that wasnt right either. Good cheap way to test it all out & at this point I'm happy enough to keep them and spend that money somewhere else.
Attached Thumbnails Riser extensions, wouuld you use them?-img_6510.jpg   Riser extensions, wouuld you use them?-img_6509.jpg   Riser extensions, wouuld you use them?-img_6511.jpg
Old Apr 10, 2016 | 08:57 PM
Mchad's Avatar
Mchad
I saw the DK's - the advantage they have is they come with the bolts. The LA Choppers version is machined to let the riser sit in a "cup" which probably makes no difference, except it looks like it would be more secure...
